Author Topic: 1.280GHz Signal Generator  (Read 5652 times)
Offline 0utsider89Topic starter
« on: August 22, 2013, 06:49:34 pm »
I want to make a cheap 1.280Ghz or 1.240Ghz  Signal Generator.
My idea is to use a SAW resonator at 640mhz in combination with a x2 multiplier to generate the 1.280Ghz signal.
Or a SAW resonator at 310MHz, with a x4 multiplier to generate a 1.240Ghz signal.
RP1105 - 640mhz, looks like you can get them.
B39311R884H210 - 310mhz
The signal generator will be used as a test bed for making amateur radio fast scan TV signals with a mixer.
Thanks,
KJ6ICA
Offline KJDS
    • my website holding page
Re: 1.280GHz Signal Generator
« Reply #1 on: August 22, 2013, 07:35:33 pm »
If you have a 10MHz reference available, then I'd use a couple of these divide by 2 to 32
http://www.hittite.com/products/view.html/view/HMC394LP4
and an off the shelf VCO and make up a phase locked loop. That way you know it will stay on frequency.
Offline marshallh
    • retroactive
Verilog tips
BGA soldering intro
« Reply #3 on: August 23, 2013, 12:16:28 am »
http://www.analog.com/en/rfif-components/pll-synthesizersvcos/adf4350/products/product.html
For the price that's not bad at all.  I'm thinking about get the Evaluation Board and do some testing, and then build my own board.
Thanks,
Offline Marco
« Reply #4 on: August 23, 2013, 10:13:28 am »
Ebay has some hobbyist frequency generators using the same chip BTW.
http://www.ebay.com/itm/RF-Signal-Generator-35MHz-to-4-4GHz-via-USB-15dBm-and-Features/200952667420
According to him it's an improved version of another design, presumably this one.
http://www.ebay.com/itm/4-4GHz-PLL-RF-Signal-Generator-Synthesizer-via-USB-/120923927269
Offline nctnico
« Reply #5 on: August 23, 2013, 11:23:58 am »
The problem with these generators is that they output lots of 2nd and third order harmonics (the output is a square wave). The seller cleverly hides that fact by showing a limited span.
Offline fcb
    • Electron Plus
« Reply #6 on: August 23, 2013, 02:30:50 pm »
I'd roll my own varactor based VCO and then use something like an ADF4107 PLL to hold it.
Much lower 2nd/3rd harmonics (easier to filter) than using a divided down generator.
Have you got an SA?
« Reply #7 on: August 23, 2013, 06:56:30 pm »
Have you got an SA?
I have a spectrum analyzer that covers the band.
That idea would work, but it could be a lot harder to build up. Its not easy to make a osc at 1.2ghz. I could be wrong though, I have not done a lot of RF design in the 1.2ghz band.
Thanks
« Last Edit: August 23, 2013, 07:16:16 pm by 0utsider89 »
« Reply #8 on: August 23, 2013, 11:00:34 pm »
And too add to that last idea it would be cheaper / easier, just to add a filter to the output of the adf4350 VCO/PLL, if I was really worry about the 2nd and 3th order harmonics. Witch in a lot of casts, would not be a problem since the 2nd order harmonic would not be passed by the antenna, and the 3th order harmonic would be so low in power, that it would not really be much of a problem.
At most my final out power is going to be around 350mW.
Offline fcb
    • Electron Plus
« Reply #9 on: August 24, 2013, 04:35:31 pm »
The ADF4350 is 2-3x the price of the ADF4107 (which is quite an expensive part anyway) - only you know your budget.  If your building a one-off, then it's cheaper to buy an RF sign gen (depending on how you cost your time).
A little colpitts oscillator is straightforward to build, Alpha appnote APN1006 might help.  And tuning for low 2/3rd is relatively easy - depends on what specs you have to meet, and how much you can get rid of in your PA.
Offline PA4TIM
« Reply #10 on: August 24, 2013, 04:42:17 pm »
I made a signal generator that does 25-2000 MHz. I used VCO's from minicircuits.
http://www.pa4tim.nl/?p=2662 for pictures. It is not ready yet. I must build the powersupply in the cabinet but I have allready tested it with the temporary psu.
You can buy a development kit direct from MC . That is much cheaper then the separate VCOPs
