Author Topic: 1.27mm pitch pad boards / matrix boards - UK source or better SMD proto ideas?  (Read 2206 times)
Offline bd139Topic starter
I've been experimenting with SMD prototyping for a few weeks now. I was working with TH stuff dead bug previously but it's really expensive and takes a lot of space storing parts which I just don't have. Now I'm doing ugly SMD stuff which is just as quick and just as functional for one-shots, prototypes etc. I don't want to spin a board necessarily for this stuff. Really I'll build a few things like this, stick them together and only spin a board if I'm happy with the outcome. Unfortunately the only 1.27 pitch boards I have are Roth ones and they actually have holes in them. Due to this, there's hardly any adhesion on the pads and if you even fart near them with a soldering iron, they lift instantly. I'll remove pads with a knife under 0805's by hand anyway.
Carnage here on an early experiment I did - the "555 hello world" circuit. This took around 10 minutes to throw together:
Ergo does anyone sell 1.27mm pitch boards in the UK/EU which don't have holes?
Or alternatively are there better solutions? I've tried dremel, scoring etc - forget it - too much effort. I'm not sitting in front of Eagle/KiCad for two hours or doing toner transfer to do a board either.
« Last Edit: November 08, 2017, 11:32:47 pm by bd139 »
Offline KL27x
Methinks you are doing it wrong. There's a copy and paste function! If you can't bother to toner transfer this, I wonder what you toner transfer, at all?
I try to keep a scrap of this stuff on hand. But I do it vero-style. It comes in handy on occasion, but you need good eyes to use it. The tiny pitch makes it just one big shine to my naked eye. If not for microscope, I wouldn't find it nearly as handy.
36 mil x 36 mil square pad. Just one thing to "make." And 10-12 mil traces. In Eagle, anyhow, you don't have to do a schematic. Just break schematic and copypasta.
*Yep. I still have two small pieces. A few square inches on 7 mil thick FR-4 will last me for many years. Usually I am using it to bodge just a part or two.
« Last Edit: November 09, 2017, 09:48:37 am by KL27x »
Offline capt bullshot
Mouser has some nice boards from BPS:
BPS SMTpads-3U-Thin (or similar), it's a double sided NPTH board with a solid plane bottom and a 1.27mm grid of pad top. Every 4th pad has a NPTH drill, you can place a piece of wire there to get a connection to the plane if required. If not, it's just a pad with a small hole in the middle, the hole usually doesn't harm.
Anyway, I don't like it anymore. Not because of it is a bad board or whatever, but rather because prototyping with SMT parts in this way costs more effort than 2.54mm THT parts.
Edit: here's a picture of such a board used in a prototype: http://wunderkis.de/idiode/index.html
« Last Edit: November 09, 2017, 10:21:45 am by capt bullshot »
The following users thanked this post: woody
As I said, I don't like prototyping SMT on a pads grid board too much,
this is better (more effort and time in total, but way more easier to solder and assemble):
And you get the schematic "for free" as you have to do it anyway (I recently switched to kicad when creating such stuff).
Offline chickenHeadKnob
Since you are in jolly olde I am surprised Mike Harrison's (mikeselectric) combination throughhole/smt board hasn't been mentioned yet, check here:
http://www.whitewing.co.uk/protoboard.html
Haven't tried these  myself. I am with capt bullshot and prefer custom boards
Offline plazma
    • Homepage
I use 1,27mm pitch board from Aliexpress. It is through plated and double sided http://plazma.kapsi.fi/pictures/temp/1.27mm_proto_board.jpg
Offline CJay
Halfway house?
http://icstripboard.co.uk/
I do like the thought that there's 1.27mm pitch board though, didn't know that and will be ordering some to try out
