Author Topic: 0.5uA detectable using mechanical meter in 1920 !  (Read 1752 times)
Offline oz2cpuTopic starter
    • webx.dk private hobby and diy stuff
« on: October 28, 2022, 08:59:28 am »
I am a little bit impressed.. it was really possible to detect 0.5uA back in 1920
see here
https://youtu.be/pmxGHhG96q4
ok it is not a lot of movement, but it is truly there :-)
Radioamateur OZ2CPU, Senior EE at Prevas
EMC RF SMPS SI PCB LAYOUT and all that stuff.
youtube : oz2cpu teardown
Offline Gyro
Re: 0.5uA detectable using mechanical meter in 1920 !
« Reply #1 on: October 28, 2022, 09:51:35 am »
Not so impressive. Mirror galvanometers (with a scale at 1m distance) of the same period, or rather earlier, could easily detect currents in the nA region.
« Last Edit: October 28, 2022, 09:53:35 am by Gyro »
Best Regards, Chris
The following users thanked this post: Someone, pardo-bsso, Johnny B Good
Offline jonpaul
« Reply #2 on: October 28, 2022, 09:56:38 am »
check Thomas Edison's "tasimeter" 1878, carbon button heat sensor....
https://en.wikipedia.org/wiki/Tasimeter
 to measure minute temperature changes in heat emitted from the Sun's corona during the July 29 solar eclipse,
Jon
Jean-Paul  the Internet Dinosaur
The following users thanked this post: Gyro
Offline Gyro
« Reply #3 on: October 28, 2022, 10:16:30 am »
My treasured Robert W Paul Sensitive Galvanometer, pre1900 (he merged with Cambridge Instruments in 1919) and single digits nA, no problem.
He was an interesting guy... https://en.wikipedia.org/wiki/Robert_W._Paul
Edit: Sorry, I should have dusted it first!
« Last Edit: October 28, 2022, 10:31:58 am by Gyro »
Best Regards, Chris
« Reply #4 on: October 28, 2022, 11:22:33 am »
wow that is some nice stuff, with that mirror you could focus a light beam and achieve a wild amplification factor,
Offline RoGeorge
« Reply #5 on: October 28, 2022, 12:50:43 pm »
You may like this channel then:
https://www.youtube.com/c/xofunkox_scientific_experiments
Magnetostriktion, Magnetostriction
For the fun of it, calculate how much change in length per mm of the light spot displacement on the scale can such an arrangement sense (an 8m length light ray reflected by a mirror glued on a 0.4mm rod turned by the change in length to measure).
Make a wild guess before calculating.  ;D
Offline Gyro
« Reply #6 on: October 28, 2022, 01:05:15 pm »
"Give me a [massless] lever long enough and a fulcrum on which to place it, and I shall move the world."  :)
Best Regards, Chris
« Reply #7 on: October 28, 2022, 03:02:17 pm »
cool video there george,
but no info about voltage / current windings ? and lightsource and dot distance ? any other mirrors ?
Online Kleinstein
« Reply #8 on: October 28, 2022, 03:15:06 pm »
There usually is only 1 mirror, though in theory a 2nd fixed mirror a bit higher / lower could give a reference to compensate movement of the light souce (usually incandecent lamp).
Today one can use a laser pointer, but the mirror galvanometers were more a thing in times before lasers.
The low mass light pointer helps to keep the response resonably fast, despite a weak restoring force from a rather thin and long ribbon.
The meters with a weaker spring and somewhat larger coil can be quite sensitive, they just get slow. A good magnet (or just brute force, large size as with the Siemens&Halske one) can also help with sensitivity.  I remember using a not that special mirror galvanometer with a thermopile, so something in the 1 mV full scale range.
Offline Terry Bites
« Reply #9 on: October 28, 2022, 04:11:23 pm »
here's a good read (if you like that kind of thing)
Offline RoGeorge
« Reply #10 on: October 28, 2022, 05:16:13 pm »
info about...
Extra info in the video description.
The following users thanked this post: oz2cpu
« Reply #11 on: October 28, 2022, 08:30:46 pm »
thanks but still dont make much sense to me :-)
why would this design be any good for any type of measurement ?
it also measure room temperature, is ultra critical mecanical, very hard to setup, not practical for anything at all.
where would this be implemented into anything real ?
Offline coppice
« Reply #12 on: October 28, 2022, 08:35:24 pm »
You do realise that precision watches operating for a couple of days from a tiny coil spring are much older than 1920, don't you? If you can make a mechanism that low power you can use the same jewelled bearing and other techniques to make an ammeter with a full scale reading of a few microamps.
Online TimFox
« Reply #13 on: October 28, 2022, 08:51:41 pm »
50 years ago, when I was an undergraduate, my physics department used traditional equipment in lab courses to teach us what really happens, rather than what comes up on a digital display, so we had wall-mounted mirror galvanometers with a telescope and arc scale for sensitive measurements.
A "ballistic galvanometer" application exploits the mechanical properties (inertia, damping, and natural frequency) of the coil and suspension, giving a maximum excursion proportional to the total charge through the instrument (integrating the current of a pulse).  https://en.wikipedia.org/wiki/Ballistic_galvanometer
I remember using a ballistic galvanometer to measure the hysteresis curve of an iron toroid ("Rowland ring")  https://solitaryroad.com/c1049.html
An interesting use of such meters, probably not used in practice anywhere, is described in  Vol. 18 of the famous "Radiation Laboratory" series:  G E Valley & H Wallman, "Vacuum Tube Amplifiers", McGraw Hill 1948.
Section 11-16 (pp 487 - 491) describes a mirror galvanometer where the reflection hits a 920 dual photodiode driving a single high-mu 6SF5 triode that applies feedback through a resistor network to the galvanometer coil.
(In the practical example, the minimum full scale was 1 microampere, not too impressive.)
The null occurs when the optical spot equally illuminates the two photocathodes.
Errors in the simple triode amplifier are negligible for that application.
« Reply #14 on: October 28, 2022, 09:03:06 pm »
HA TIM !!
I think you just explained exactly how this weight scale works
https://youtu.be/dwMl0CTE5j4
Online TimFox
« Reply #15 on: October 28, 2022, 09:29:43 pm »
What I liked about the galvanometer circuit I found in the old Rad Lab book was that the galvanometer itself was in the null comparator for a feedback amplifier, and most of the errors from the light source and the rest of the circuit were made negligible by the huge gain (from galvanometer angle to differential voltage into the triode) due to optical leverage.
Offline RoGeorge
« Reply #16 on: October 28, 2022, 10:26:03 pm »
That video was about the incredible resolution in measuring a mechanical displacement achieved with only a pin, a mirror and a bit of ingenuity.
Magnetostriction (cf. electrostriction) is a property of magnetic materials that causes them to change their shape or dimensions during the process of magnetization.
That device measures how much a piece of wire changes its length when a magnetic field is applied.  The coil, voltage and current are there only to produce a magnetic field that can be turned on/off.  When the magnetic field is applied, the piece of wire going through the core of the coil changes its length a little bit.
How would you measure with how much the length of the wire changed?
In that apparatus, the piece of wire sits on a 0.4mm diameter pin (rod), and when the wire changes its length, it rotates a little the 0.4mm pin.  And on the pin is glued a little mirror that changes its angle because of that little rotation.  Then the light deflected by the little rotating mirror travels to a screen that is placed 8 meters away (the spot of light seen on the right side of the video).
That very simple mechanical only measurement can sense a change in length of only 25nm (caused by the magnetostriction effect).  That's somewhere between the size of a virus (100nm) and a protein (10nm), or how much your hair grows in 7 seconds or so (if I didn't mess the calculations, the only reason I was challenging you to calculate the sensitivity of that instrument).  ;D
« Last Edit: October 29, 2022, 10:00:47 am by RoGeorge »
