Author Topic: Fluke 187 IR cable  (Read 5211 times)
Offline mrjodaTopic starter
  • Country: sk
Fluke 187 IR cable
« on: June 06, 2016, 08:16:03 pm »
Hi friends
I bought F187 for a few bucks so... here is my DIY fluke IR USB cable attachment.
Circuit is basic connection of FTDI FT232RL with one LM393 at output/input. Powered from USB. I saw this schematic somewhere on internet but i dont have link.
PCB is little bit fancy. It has 13,7x23,20mm double sided.
The body of connector is 3D printed from PLA.
gerbers and steps are included down.
i works with flukeview form with no issues.
The following users thanked this post: BravoV, rernexy
Offline BravoV
  • +++ ATH1
Re: Fluke 187 IR cable
« Reply #1 on: June 07, 2016, 02:26:38 am »
Nice  :-+, thanks for sharing, I like the idea of the 3D printed connector body.  :clap:
Offline serggio
  • Country: ru
Fluke 187 IR cable
« Reply #2 on: June 10, 2016, 06:47:57 pm »
Disaster...
Seems that people absolutely not understand schematic and just try to do copy-past solution where comparator was used for drive emitting diode and convert photodiode level. http://kimboricha.blogspot.ru/2013/12/build-usb-to-fluke-189-irinfrared.html
Now carefully look at your schematic where you use 10k/10k R1/R3 divider. What reverence voltage you will have on inverted input on comparator? I assume that this will be 5/2 = 2,5 V
And what role LM393 here in your schematic, when you can easy exclude it and connect your emitting and receiving diodes directly to Rx and Tx line?  :clap:
« Last Edit: June 10, 2016, 09:03:13 pm by serggio »
Offline michal82
« Reply #3 on: June 17, 2017, 08:51:31 pm »
Hello
At what wavelength did you use the transmitter and receiver.
800nm, 880nm or 950nm?
Offline serggio
  • Country: ru
« Reply #4 on: June 17, 2017, 09:09:57 pm »
950 will work, 880 will work, don't worry about it
