A 1 kilohm variable resistor in place of R1 would do it.
Hello,So I have this SMPS unit:and would like to add a variable resistor to a TL494 based power supply I've seen other people do it but on another types and would like to know how to do it in here where is the resistor that controls the current limiting and what value pot should it be replaced with?Help is very appreciated.Thanks for your time.Here is the reference schematic in the datasheet.
Quote from: David Hess on August 04, 2017, 04:15:44 pmA 1 kilohm variable resistor in place of R1 would do it.So I located that resistor on my PSU and it was 68KOhm so I replaced it with a 50KOhm Pot now when connecting a 2A load to it and turnin the pot to min or max it doesn't have any affect on voltage or current you sure it's that resistor?Also what is the math for the current behind it?
I don't see a current transformer, nor an auxiliary power supply for the controller.I doubt you'll be able to get much adjustable range before the controller starts hiccuping, and no such thing as CC operation.Tim
