Author Topic: Advantest R3265A Composite Video Out  (Read 4194 times)
Offline james_s
Re: Advantest R3265A Composite Video Out
« Reply #25 on: May 18, 2023, 06:37:31 pm »
The most likely explanation is that the analyser outputs a non-interlaced signal which is not strictly any of 525/60 or 625/50 standards but close enough for "analogue displays".  The AV2HDMI converter is expecting more rigid adherence to one of those.
This is almost certainly the case. These converters are way more fussy than an analog CRT. NTSC is interlaced with quite precise timings, it is very common for computers and video games and such to produce a non-interlaced signal that is close enough to NTSC timings for a CRT to work fine, but it won't work with something that is expecting interlaced NTSC video.
I have used one of those cheap little backup camera LCD monitors for testing early arcade boards and FPGA implementations of them so some LCD monitors do handle these odd signals just fine.
Offline vk6zgo
« Reply #26 on: May 19, 2023, 12:50:44 am »
Either I'm phrasing badly or you deliberately misreprensent what I said.
My point was, that there are practically no CVBS-to-HDMI converters on the market. On the other hand, plenty of VGA-to-HDMI, but connecting those directly to CVBS is bound to fail due to the low scan rate of CVBS.
I am an old-style Broadcast standard TV person, so I normally think PAL/NTSC Composite video.
Googling verifies my vague ideas about VGA as basically an RGB system with separate Horizontal & vertical sync connections, normally implemented using a 15 pin D-sub connector, or sometimes with four BNC connectors. (Some of the incidental functions normally available with the 15 pin connectors are not available in the latter case.)
If a converter is fitted with a single BNC/RCA video input & a HDMI output socket, it is fairly certain to be Composite video to HDMI.
Googling, I found just as many CVBS to HDMI adaptors offered as VGA to HDMI ones.
The market for the former is quite likely to be larger than the latter, as more people have legacy video sources than those who want to use an older computer with a modern monitor.
Offline vk6zgo
« Reply #27 on: May 19, 2023, 01:14:11 am »
Yes, analog monitors/TVs normally run the horizontal & vertical oscillators constantly, whether there are syncs available or not.
Their free running rate is close to the nominal locked frequencies, & when they receive syncs, being basically PLLs, will lock to them.
Except for very early systems like the old UK 405 line system, the line frequency of analog TV standards are very close & will lock without difficulty.
Field rates may require a "tweak" of the vertical hold preset pot, although the last generation of TVs could recognise the 50Hz & 60 Hz systems & self-adjust.
If a converter requires very precise timing, it might well become "confused".
I am still suspicious that the Field & Line sync signals in the R3265A may not be locked.
This can be easily checked by displaying the video waveform at field rate.
If the H syncs are not locked to the V ones, they will drift through the display, just as they do on the monitor.
