[quote author=nukie link=topic=9807.msg134247#msg134247 date=1343870571
Nowadays there's another solution, that is to learn Solidworks, then send off the drawing to a machining shop where the CNC machines do their job. This is similar to home DIY etch PCB vs professionally shop made PCB.
I think you will find the costs of that method prohibitively expensive unless you are talking large quantities
Edit: I just sent off to "firstcut prototype services" the nose piece and the brass inner piece you saw in the video to be quoted for 10 pieces of each. I will report back what type of prices I get if any. I suspect they will balk at the rectangular broached holes in both pieces.
[/quote]
As I suspected Firstcut (machining) and protomold (molding) would not quote the parts because of being below their 1/4" size limit. And the rectangular broached holes were a problem anyhow.
Email from them:
Thank you for sending us your parts to quote.
Due to the thin walls on the parts listed below, they are not a good fit with the Firstcut manufacturing process. If the walls can be thickened to at least 0.040 (1mm), please send revised 3D files. We will provide a quote as quickly as possible. If you have any questions, please feel free to contact me.
General machining is a different animal than PCB's or things that will be rapid prototyped by any of the current methods. The latter two don't need much specialist input beyond what is defined in the files sent to the service. Machining does need a lot of human decision making based on what machines/processes are available even when using a CAM system for the programming of the CNC machines.
