Author Topic: The Rust Megathread  (Read 31260 times)
Offline Raymund Hofmann
Re: The Rust Megathread
« Reply #100 on: August 07, 2019, 04:51:24 pm »
Offline tggzzz
« Reply #101 on: August 07, 2019, 06:47:30 pm »
And then there's the Dunning-Kruger effect.
My entire business runs on pretending that doesn't exist :)
Does that make you a disaster capitalist?
Offline tggzzz
« Reply #102 on: August 07, 2019, 06:52:33 pm »
C-like languages are dead in that space. Everything is too mutable to handle concurrency effectively and scale well. Most of the synchronisation primitives we use are to work around that.
The concurrency problem is not a problem of the language, it is a problem of the programmer.
If the language doesn't haver primitives with the necessary semantics, then even the best programmer cannot succeed. Those with Dunning-Jruger syndrome might think they have succeeded, but...
If you build a castle on sand, it doesn't matter how good the builders are.
Until very recently, c didn't have the semantics. It remains to be seen whether the semantics are sufficient, and whether they are implemented correctly.
Looks like you just read the first sentence and it was sufficient to trigger your denial. Isn't that what Dunning Kruger described?
My point was that burdening the programmer with more primitives and semantics probably will not work, because if it would, it could have worked since more than 20 years and we wouldn't wait for anything to compute while 7/8 cores and 2 GPUs are idling.
You need the right concepts and semantics, and the fewer the better.
C++ explicitly avoided choosing a few simple semantics in favour of letting each programmer choose a different (often incompatible) of the language and concepts.
Apart from that you are discussing application lspecific issues, not language issues.
Offline tggzzz
« Reply #103 on: August 07, 2019, 07:01:55 pm »
Had a interesting read about the "safety" of Rust.
https://medium.com/@shnatsel/how-rusts-standard-library-was-vulnerable-for-years-and-nobody-noticed-aebf0503c3d6
You seem to see the world in black and white; you misinterpret and misrepresent what other people are saying as X is all good or all bad.
In reality the world is shades of grey. In this case c is blacker and rust might be whiter.
I distrust anyone that doesn't recognise greyness, since it shows imbalance.
« Reply #104 on: August 07, 2019, 07:35:03 pm »
Opportunist perhaps. In the house of the blind, the man with one eye is king. Unfortunately half the house wants your advice and the other side want to poke your good eye out.
Grey is an understatement. Everything is somewhere to the side of the scale. It’s brown and stinks. Product selection is about extracting the juicy bits of sweetcorn from the turd. It’s still a turd though and you have to eat it every day. Yum.
The following users thanked this post: barycentric
« Reply #105 on: August 09, 2019, 08:32:11 am »
So you pretend it doesn't apply to you?
« Reply #106 on: August 09, 2019, 08:52:20 am »
No, just the business. The business is a facade. If someone comes with a problem, the business must sell an answer or turn a customer away, the latter of which is poor business acumen. Thus the business knows everything and is not subject to that theory, with the disclaimer of a lead time, exploration, analysis and a price. It's my responsibility to make sure that when it applies to me personally, I bridge the gap between ignorance and competence properly before reaching any conclusions. This is how think tanks, research companies and consultancies operate. Well the honest ones anyway.
The dishonest ones usually have a book of answers available ranked in order of cash backhanders for product recommendations.
Offline tggzzz
« Reply #107 on: August 09, 2019, 09:14:56 am »
Fortunately, while I've occasionally got it wrong, I've a pretty good track record of spotting the sweetcorn.
One of the more unpleasant examples was of selecting a good product from a great company and team. They were so good they were borged by Oracle, and we all know where that leads :(
« Reply #108 on: August 09, 2019, 09:38:23 am »
Ah yes. Been there. I got hired to port something away from Sleepycat to SQLite when Oracle rolled up to buy them out.
Edit: I was actually Oracle 9i DBA for a bit on HP/UX (back in the days of N-class hardware with the promise of Itanium on the horizon) because the usual suspect decided to go and drive his stupid Lotus car into a tree. I was offered cert but declined it as it was like wearing a nazi uniform :)
« Last Edit: August 09, 2019, 09:40:57 am by bd139 »
Offline SiliconWizard
« Reply #109 on: September 01, 2019, 11:06:37 pm »
So anyway... has anyone here developed something interesting with Rust?
« Reply #110 on: September 01, 2019, 11:07:36 pm »
No just marketing  :-DD
Offline coppice
« Reply #111 on: September 02, 2019, 01:31:20 am »
You mean like recording tape, or floppy disks?
« Reply #112 on: September 02, 2019, 02:20:35 pm »
Rust not rust.
And that was a genuine question. ;D
And I meant someone from the forum, not someone from Mozilla.
