Let's go on a bit of a tangent, then, related to blocks delimiters. (Python and Makefiles use indentation and not delimiters; and Makefiles' one is even more annoying, because it does distinguish between tab and space as the first character in indentation. I avoid that mess by using four spaces per indentation level in Python, and only a single tab in Makefiles.)
It seems that those who dislike indentation, prefer braces AKA curly brackets, { and } as the block delimiters. These are used in many languages (C, C++, Java, Javascript, Awk, CSS, Tex/LaTeX/MathJax) which makes them familiar to many. Are there any better suggestions?
Some languages (note I'm using 'languages' as the superset of 'programming languages', 'domain-specific languages', and 'markup languages' here) use different delimiters. The most different being the way XML has each block start paired with a corresponding end block, <tag ... >...</tag>; and later versions of Fortran's do/for/while/etc. paired with an end with an optional block type (i.e.end do,end for, etc.) The XML one has proven problematic for humans (especially since things like <a>...[/url] are typical human "errors"), leading to abandonment of XHTML in current HTML version, HTML5.
I've mentioned before in other threads that I myself like a variant of LaTeX, but with escape sequences that ensure the block structure characters do not occur anywhere else in the stream. For example, if { begins a block, | separates sibling blocks, } ends a block, and \ precedes an escape sequence, I'd prefer \/, \(, \), and \! to escape \ { } | in the content, correspondingly. It may not be a good idea for a programming language, because code must be maintainable and therefore easy for humans to understand at a glance; but for markup languages, it beats the shit out of XML and others in parser speed, efficiency, and possibilities (which include parsing the stream backwards), with just a couple of characters worth of buffering either way.
It is also notable that both ASCII and Unicode include dedicated control characters (and dedicated control glyphs in Unicode, in addition to the ASCII ones). Should we at some point switch from plain ASCII source code formats, into structured formats where the editor displays the code in whatever format the programmer wants – be that whitespace-indented or brace delimited or something more funky – and just uses a markup language underneath?
