Author Topic: pickit 3 not working in windows 10  (Read 10701 times)
Offline james101Topic starter
« on: February 01, 2021, 12:50:32 am »
Hi guys  can anyone help us how to get a pickit3 working on windows 10 64bit.
i tried to install it and im getting a error communications
in devices it showing the yellow error mark for the USB drivers.
is there some other USB drivers that will work with this unit
i have tried 2 pick-its now with the same issues.
thank you
Offline DrG
Re: pickit 3 not working in windows 10
« Reply #1 on: February 01, 2021, 01:04:54 am »
thank you
Just for S&G, I searched on - pickit 3 not working in windows 10- no quotes and Google dutifully informed me that there are 20,700,000 hits.
Nevertheless, there are some links that look helpful, like the "hold the button down" when plugging it in and reinstall and even mess with the registry in this thread - https://www.microchip.com/forums/m936066.aspx
Be sure to tell us what ends up working for you.
- Invest in science - it pays big dividends. -
The following users thanked this post: james101
Online oPossum
« Reply #2 on: February 01, 2021, 01:52:54 am »
Make sure you are using a recent version of MPLAB X. That will have the 64 bit drivers.
Online coromonadalix
« Reply #3 on: February 01, 2021, 06:05:04 pm »
works fine for me in win 10, installed mplab ide 3.50
you do need the drivers to make it work
« Reply #4 on: February 02, 2021, 12:54:25 am »
HI i read google i spent all night trying to get this working.
it comes up USB unrecognized
loaded up the software and it does not communicated with the computer
the  registry hack was mainly for windows 8 users.
i downloaded mp-lab IDE 3.50
just wondering what the setting would  be under devices .
as it says select drivers.
as a last resort i just order another new one.
but i have two pic-kit 3 with the same issues.
also tried it on windows 7 again does not work comes up with the same error
any other test i could try.
does this sound like the devices could be bricked
thank you
Online oPossum
« Reply #5 on: February 02, 2021, 05:41:24 am »
Could be a USB cable or hub problem.
The red USB cable that came with some of the PICkit3 was of rather poor quality.
Offline ace1903
  • Country: mk
« Reply #6 on: February 02, 2021, 10:19:39 am »
Check with PICKit3 GUI application. Hardware maybe needs to be switched to MPlab mode.
I use pickit3 on windows64 several years and it is fine. MPLABX has some problems with PICKIT3 and some newer micros.
PicKit3 standalone GUI application will show you if the problem is in the hardware or into the software.
Offline DrG
« Reply #7 on: February 02, 2021, 03:48:20 pm »
thank you
ugh maybe it is bricked. I still have mine, but it would sometimes become unreadable by win 7 and it would get fixed but I don't know how (tried so many things). Eventually, I went to PicKit 4 and have not (yet) had any problems. "i downloaded mp-lab IDE 3.50" - mplab x ide is at 5.40 btw. In any event GL!
Offline DrG
« Reply #8 on: February 22, 2021, 05:52:06 pm »
@james101 Did you get this resolved? If so, what was the conclusion?
Offline nicknails
« Reply #9 on: February 23, 2021, 02:31:50 pm »
Make sure you're using a USB cable that's not just for charging. I was fighting with a curiosity dev board and was trying to use a cable that came with some other device that didn't have all the wires needed for communication, just charging. I switched to a different cable and it worked fine.
Offline PKTKS
  • Country: br
« Reply #10 on: February 24, 2021, 02:34:39 pm »
Just for fun... (i know myself this is not fun...  ??? )
Try  samsung+scanner+not+working+windows+10  (over 1.8 MILLION results)
https://www.google.ca/search?q=samsung+scanner+not+working+windows+10&oq=samsung+scanner+not+working+windows+10
And samsung+multifuncional+printer+not+working+windows+10  ( over 5 MILLION results)
https://www.google.ca/search?q=samsung+multifuncional+printer+not+working+windows+10&oq=samsung+multifuncional+printer+not+working+windows+10
Wiped that garbage out after the UPDATE suggested just bricked some PCs.
Enough
Paul
Offline Jan Audio
« Reply #11 on: February 24, 2021, 04:19:42 pm »
Do you have a real PicKit3 ?, or a real chinese version from alibay ?
Offline oliviasmithh900
« Reply #12 on: March 08, 2021, 12:52:39 am »
Its normally resolved after software upgradation
Offline Anobium
« Reply #13 on: March 08, 2021, 10:34:40 am »
PICkit3 does work with Windows 10 ... see www.pickplus.co.uk for the software.
