I was specifically referring to running on a small embedded target. I guess these days people consider a rPi to be a small embedded target. Or are you talking about targets like a CM0 ARM or an 8 bit PIC?
Yeah I am talking about bare metal programming. 8-bit, 16-bit, 32-bit microcontrollers. ARM based too like STM32.
Am I wrong? Is Forth better than C?
Sorry I don't know much about Forth, actually I have biased opinion about C...
In one regard, Forth is closely to the bare metal of the CPU than C - namely, the use of the stack. Forth uses reverse polish notation for (just about) everything. i.e., if you want to add two numbers together, you push them both on the stack and then issue the command:
2 5 add .
will give 7 (. prints the number at the top of the stack).
In C, pushing/popping the stack is hidden from the programmer but the executable code the compiler generates will typically push values onto the stack prior to calling the appropriate routine.
However, at the CPU's register level, C closely resembles the metal, as it were. Forth doesn't. Indeed, in some ways, the only way that Forth directly maps to the underlying processor is through the bit length of the word used.
The stack/RPN concept can be extremely powerful. It is neither better nor worse than C. It's different. I am aware than some implementations of Forth exist as usable from within compilers for other languages, such as how many C/C++ compilers can accommodate assembler.
