This is the principle, talking about the reference signal first:
- the green trace, V(sin), is the reference signal from the AWG, the one that sweeps in frequency over time
- the yellow trace, V(cos), will have to be reconstructed in software. This is possible from only one sample, and for each sample, because at any moment we know the value and the frequency of the reference signal.
- then each sample can be square to get the magenta and the grey traces respectively, V(sin
2) and V(cos
2). Note how the square signal is also a sinusoidal, always positive, and in antiphase (also has double the frequency of the original reference).
- now if we add these two, we get a constant value proportional with the amplitude of the reference signal, just that we can compute it for each and every signal, even for the moments when the reference signal (green trace) is crossing through zero.
A single sample, even when zero, can tell the amplitude.
Now, can we do the same for noisy signal to measure, coming from an unknown circuit? Let's assume at first the unknown circuit is linear (LTI) therefore the unknown circuit can change the phase and/or the amplitude, but can not introduce new harmonics
- the measured signal from the unknown circuit will have noise, a different amplitude and a different phase than the reference signal
- however, the circuit doesn't know the difference between a sin and a cos, so it will alter the reference signal with the same change in amplitude and in phase no matter it's sin or cos. This means that we can produce (in software) a quadrature signal for the unknown measured signal, similar with how we did for the reference signal.
And here is a little stretch (more assumptions about the measured signal), trying to benefit from additional knowledge we have about the reference signal:
- we know the frequency at any moment
- we know sin and cos are in fact the same function, but shifted in time with 90 degrees (it's easy to observe this in the green and yellow traces)
- so to reconstruct the cos signal in software, we just copy the sin with a pi/2 delay. This pi/2 (delay) varies with frequency, but the frequency is known at any moment relative to the start of a chirp, it's the same frequency as in the reference signal.
It looks like the same reconstruction can be possible for the measured signal, too, assuming the amplitude and phase doesn't change dramatically over the time of a quarter of a period, which I think it's safe to assume for a slow enough sweep.
TL;DR the amplitude of the unknown signal can be deduced from a single sample (once we have acquired and post-process enough samples along the frequency sweep, so we can copy the sample from pi/2 behind as the cos of the measured sin(x)).
It looks like, there is no need of FFT, or DFT, or WT when DUT is a linear circuits. A variable time shift with pi/2 to approximate cos(x), then square the two samples for sin(x) and cos(x), then adding their squared value will get the amplitude frequency response at each sample, which amplitude can be averaged to filter out a part of the noise.
Should work. Or am I missing something?
The tricky part comes if the unknown circuit is non linear. This will add harmonics, and intermodulation products, and so on. The previous trick might not be applicable, but at least the fundamental frequency of all the harmonics is known. Not sure what to do for the non linear circuits. I need to think more about it, and here it's already early AM hours.
