hi all,im trying to load this into a uno but get these errors,any ideas what is wrong?
#include<JC_Button.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
const float Low_BAT_level = 3.0;
//Current steps with a 3R load (R7)
const int Current [] = {0,100,200,300,400,500,600,700,800,900,1000};
const byte PWM_Pin = 10;
const byte Buzzer = 9;
const int BAT_Pin = A1;
int PWM_Value = 0;
unsigned long Capacity = 0;
int ADC_Value = 0;
float Vcc = 4.28; // Voltage of Arduino 5V pin ( Mesured by Multimeter )
float BAT_Voltage = 0;
float sample =0;
byte Hour = 0, Minute = 0, Second = 0;
bool calc = false, Done = false;
Button UP_Button(2, 25, false, true);
Button Down_Button(3, 25, false, true);
void setup () {
Serial.begin(9600);
pinMode(PWM_Pin, OUTPUT);
pinMode(Buzzer, OUTPUT);
analogWrite(PWM_Pin, PWM_Value);
UP_Button.begin();
Down_Button.begin();
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.setTextColor(WHITE);
display.setTextSize(2);
display.setCursor(12,25);
display.print("EASY TECH");
display.display();
delay(2000);
display.setCursor(2,15);
display.print("Adj Curr:");
display.setCursor(2,40);
display.print("UP/Down:");
display.print("0");
display.display();
//************************* End of Setup function *******************************
void loop() {
UP_Button.read();
Down_Button.read();
if (UP_Button.wasReleased() && PWM_Value < 256 && calc == false)
PWM_Value = PWM_Value + 25;
if(PWM_Value > 256){
PWM_Value=PWM_Value-25;
analogWrite(PWM_Pin,PWM_Value);
display.setCursor(2,25);
display.print("Curr:");
display.print(String(Current[PWM_Value / 25])+"mA");
display.display();
Serial.println(String(Current[PWM_Value / 25]));
Serial.print(PWM_Value);
if (Down_Button.wasReleased() && PWM_Value > 1 && calc == false)
PWM_Value = PWM_Value - 25;
display.display();
Serial.println(String(Current[PWM_Value / 25]) + "mA");
if (UP_Button.pressedFor (1000) && calc == false)
digitalWrite(Buzzer, HIGH);
delay(100);
digitalWrite(Buzzer, LOW);
timerInterrupt();
//************************* End of Loop function *******************************
void timerInterrupt(){
calc = true;
while (Done == false) {
Second ++;
if (Second == 60) {
Second = 0;
Minute ++;
if (Minute == 60) {
Minute = 0;
Hour ++;
//************ Measuring Battery Voltage ***********
for(int i=0;i< 100;i++)
sample=sample+analogRead(BAT_Pin); //read the Battery voltage
delay (2);
sample=sample/100;
BAT_Voltage = sample * Vcc/ 1024.0;
display.setCursor(20,5);
display.print(String(Hour) + ":" + String(Minute) + ":" + String(Second));
display.setTextSize(1);
display.setCursor(0,25);
display.print("Disch Curr: ");
display.print("Bat Volt:" + String(BAT_Voltage)+"V" );
Capacity = (Hour * 3600) + (Minute * 60) + Second;
Capacity = (Capacity * Current[PWM_Value / 25]) / 3600;
display.setCursor(2, 55);
display.print("Capacity:" + String(Capacity) + "mAh");
display.display();
if (BAT_Voltage < Low_BAT_level)
display.print("Capacity:");
display.print(String(Capacity) + "mAh");
display.display();
Done = true;
PWM_Value = 0;
delay(100);
delay(100);
delay(100);
delay(100);
delay(1000);
i get these errors:Arduino: 1.8.13 (Windows 7), Board: "Arduino Uno"
sketch_dec13a:180:1: error: expected unqualified-id before numeric constant
1
sketch_dec13a:371:13: error: redefinition of 'const float Low_BAT_level'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:13:13: note: 'const float Low_BAT_level' previously defined here
sketch_dec13a:373:20: error: redefinition of 'const int Current []'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:15:11: note: 'const int Current [11]' previously defined here
sketch_dec13a:374:12: error: redefinition of 'const byte PWM_Pin'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:16:12: note: 'const byte PWM_Pin' previously defined here
sketch_dec13a:375:12: error: redefinition of 'const byte Buzzer'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:17:12: note: 'const byte Buzzer' previously defined here
sketch_dec13a:376:11: error: redefinition of 'const int BAT_Pin'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:18:11: note: 'const int BAT_Pin' previously defined here
sketch_dec13a:377:5: error: redefinition of 'int PWM_Value'
int PWM_Value = 0;
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:19:5: note: 'int PWM_Value' previously defined here
int PWM_Value = 0;
sketch_dec13a:378:15: error: redefinition of 'long unsigned int Capacity'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:20:15: note: 'long unsigned int Capacity' previously defined here
sketch_dec13a:379:5: error: redefinition of 'int ADC_Value'
int ADC_Value = 0;
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:21:5: note: 'int ADC_Value' previously defined here
int ADC_Value = 0;
sketch_dec13a:380:7: error: redefinition of 'float Vcc'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:22:7: note: 'float Vcc' previously defined here
sketch_dec13a:381:7: error: redefinition of 'float BAT_Voltage'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:23:7: note: 'float BAT_Voltage' previously defined here
sketch_dec13a:382:7: error: redefinition of 'float sample'
float sample =0;
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:24:7: note: 'float sample' previously defined here
float sample =0;
sketch_dec13a:383:6: error: redefinition of 'byte Hour'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:25:6: note: 'byte Hour' previously defined here
sketch_dec13a:383:16: error: redefinition of 'byte Minute'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:25:16: note: 'byte Minute' previously defined here
sketch_dec13a:383:28: error: redefinition of 'byte Second'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:25:28: note: 'byte Second' previously defined here
sketch_dec13a:384:6: error: redefinition of 'bool calc'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:26:6: note: 'bool calc' previously defined here
sketch_dec13a:384:20: error: redefinition of 'bool Done'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:26:20: note: 'bool Done' previously defined here
sketch_dec13a:385:17: error: redefinition of 'Button UP_Button'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:27:8: note: 'Button UP_Button' previously declared here
sketch_dec13a:386:19: error: redefinition of 'Button Down_Button'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:28:8: note: 'Button Down_Button' previously declared here
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino: In function 'void setup()':
sketch_dec13a:389:6: error: redefinition of 'void setup()'
void setup () {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:31:6: note: 'void setup()' previously defined here
void setup () {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino: In function 'void loop()':
sketch_dec13a:417:6: error: redefinition of 'void loop()'
void loop() {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:59:6: note: 'void loop()' previously defined here
void loop() {
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino: In function 'void timerInterrupt()':
sketch_dec13a:461:6: error: redefinition of 'void timerInterrupt()'
C:\Users\me\Desktop\sketch_dec13a\sketch_dec13a.ino:103:6: note: 'void timerInterrupt()' previously defined here
sketch_dec13a:536:7: error: redefinition of 'void setup()'
void setup() {
void setup () {
sketch_dec13a:541:6: error: redefinition of 'void loop()'
void loop() {
void loop() {
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
