Yes, forgot to mention that resource, thank you for posting it.
From yesterday's checks, it looks like all his findings are already upstream in the patch_ca0132.c file. I've diff-ed against the latest kernel from Linus' github repo and nothing has changed in years. Found the tools, too. Those are gold in case I've ever want to sniff the messages between the Windows driver and the Windows OS, but I don't think I'll go there.
I don't need to change anything to my soundcard for its daily use, and if it were to really want to record in 24 bits then I'll just install Windows and use the proprietary Creative drivers for Windows.
Though recording in 24 bits for this soundcard would be kind of futile, because the card is too noisy, especially at high sampling rates. This is the typical noise floor (the picture is from another topic, please consider only the noise floor and ignore the signal):
All this dive into the Linux sound was mostly for learning. So far it was very interesting for me, I've learn about PulseAudio/Jack/PipeWire + ALSA/OSS + Intel HDA + Linux modules/drivers + recompile own changes and/or add custom kernels to GRUB + many other thing.
As a matter of fact, it happens that only seconds ago I was playing with an algorithm specific to emu10k family of DSP's, from the exact github repo you just mentioned.
The algorithm is bamboozling looking at the C code implementation. It computes logarithms or exponentials.
It is suppose to be DSP stile, which in hardware is usually implement with a hardware multiplier and an accumulator, so I'm trying to figure out the hardware that would correspond to the algorithm, or at least a block representation with Z
-1 steps, like in filters.
I compiled the C emulation (since it happened that I'm in FreeBSD now, there is no <linux/types.h> so I've blindly used #include <infiniband/types.h>, not sure if this ruins it, I hope not, but at least it compiles).
Made a script to run it for a range of inputs, then pasted the data in a spreadsheet to make a chart. Well, the shape does look like either as an exponential decay or as a logarithmic increase (looks exactly like the response of an RC circuit, if it were to think in terms passive resistors/capacitors filters).
If anybody curious for a code puzzle, this is the C code for it:
* This file was taken from the emu10k1 archives. I've cleaned up the code a
* bit and fixed some of the bugs, but other than that it's unchanged.
/* By: Daniel Bertrand
Date: Nov 6th, 2000
Description: A software implementation of creatives LOG and EXP instructions
found in the emu10k1 processor. (Patent: WO 9901814 (A1))
I'm not sure if this is even legal, being a software implementation of a patented hardware instruction,
so I'm releasing it into the public domain (no license, no copyright).
Compiling:
exp:
gcc explog.c -o exp
usage:
./exp <log_data> <max_exponent_size> <Sign_control>
log:
gcc explog.c -DLOG -o log
usage:
./log <lin_data> <max_exponent_size> <Sign_control>
log converts linear to logarithmic
exp converts logarithmic to linear
Logarithmic representation:
| 31 |30 29-25|28-24 0|
|sign| exponent | Mantissa |
exponent size varies between 2 and 5 bits,
<max_exp_size> is specified in actual value, thus 3 bits is <max_exp_size>=7
max_exp_size can be anyvalue between 2 and 31.
#include <stdio.h>
#include <stdlib.h>
#include <linux/types.h>
search for existing replacements:
find /usr/include -iname types.h
/usr/include/rpc/types.h
/usr/include/sys/types.h
/usr/include/infiniband/types.h
__u32 log1(__u32 lin_data,__u32 max_exp,__u32 sign_ctrl)
int exp = (int)max_exp + 1;
__u32 result;
__u8 sign;
//FIX ME: mask inputs (i think this is what it does, haven't checked it yet):
sign_ctrl &= 0x03;
max_exp &= 0x1f;
sign = (lin_data >> 31) & 0x01;
/* Smallest exponent value is 2, if we're below that, default to 2. */
if (max_exp < 2)
max_exp = 2;
/* If the value is negative, one's complement the bits. */
if (sign)
lin_data= ~lin_data;
* Continue to shift left until we either:
* - End up with the exponent being 0.
* - Or end up with the MSB set.
while (!(lin_data & 0x80000000)) {
lin_data <<= 1;
exp--;
if (!exp)
break;
* If the exponent is not 0, shift left by 1 to get rid of the
* implicit bit.
if (exp)
lin_data <<= 1;
if (max_exp & 0x10)
result = (exp << 26) | (lin_data >> 6);
else if (max_exp & 0x8)
result = (exp << 27) | (lin_data >> 5);
else if (max_exp & 0x4)
result = (exp << 28) | (lin_data >> 4);
else
result = (exp << 29) | (lin_data >> 3);
printf("Exponent %d, mantissa 0x%08x, result 0x%08x.\n", exp, ((lin_data >> 1) + 0x80000000) >> 6, result);
Sign control
the result is complemented depending on the following conditions
| Sign Control | sign=0 | sign=1 |
| 00 | R | ~R |
| 01 | R | R |
| 10 | ~R | ~R |
| 11 | ~R | R |
switch( sign_ctrl){
case 0:
if (sign)
result = ~result;
break;
case 2:
result = ~result;
break;
case 3:
if (!sign)
result= ~result;
break;
default:
break;
return result;
__u32 exp1(__u32 log_data,__u32 max_exp,__u32 sign_ctrl)
__u32 result;
__u8 sign;
sign_ctrl &= 0x03;
max_exp &= 0x1f;
sign = (log_data >> 31) & 0x01;
if (max_exp < 2)
max_exp = 2;
if (sign)
log_data = ~log_data;
//seperate mantissa and exponent
if (max_exp & 0x10) {
exp = log_data >> 26;
log_data <<= 6;
} else if (max_exp & 0x8) {
exp = log_data >> 27;
log_data <<= 5;
} else if (max_exp & 0x4) {
exp = log_data >> 28;
log_data <<= 4;
} else {
exp = log_data >> 29;
log_data <<= 3;
//put back the implicit 1
if (exp) {
log_data >>= 1;
log_data |= 0x80000000;
exp--;
//shift mantissa back down
result = log_data >> (max_exp - exp);
//handle sign
switch( sign_ctrl){
case 0:
if(sign!=0)
result= ~result;
return result;
case 1:
return result;
case 2:
return ~result;
case 3:
if(sign==0)
result= ~result;
return result;
int main (int argc, char *argv[])
if(argc!=4){
printf("usage: log <lin_value> <max exponent size> <sign control>");
return -1;
#ifdef LOG
printf("0x%08x\n",log1(strtoul(argv[1],NULL,16),strtoul(argv[2],NULL,16),strtoul(argv[3],NULL,16) ));
#else
printf("0x%08x\n",exp1(strtoul(argv[1],NULL,16),strtoul(argv[2],NULL,16),strtoul(argv[3],NULL,16) ));
#endif
return 0;
Source:
https://github.com/Conmanx360/ca0132-tools/tree/master/documentationCompiled it with "gcc emu10k1-explog.c -o explog", and when executed like this:
#!/usr/bin/env bash
#!/bin/bash
for i in {0..50}
do
./explog 10 $i 1
done
and it produces something like this:
Guess I should probably browse the other input parameter.
