Microsoft's VScode is, IMHO, the best IDE out there. It is also free and open source.
However, when the git sources are turned into binary installers, Microsoft adds its own custom settings, settings that are not included in the public git repository. Of course, advanced users can always compile their own VScode started from sources, but this is time consuming and requires very specific settings.
Codium is Visual Studio Code, but with community maintained default settings, and community prepared installers, no Microsoft defaults. Same functionality but with less distractions, telemetry disabled, and so on:
https://gitlab.com/paulcarroty/vscodium-deb-rpm-repoFor example, to install Codium in Ubuntu:
wget -qO - https://gitlab.com/paulcarroty/vscodium-deb-rpm-repo/raw/master/pub.gpg | sudo apt-key add -
sudo apt-add-repository 'deb https://paulcarroty.gitlab.io/vscodium-deb-rpm-repo/debs/ vscodium main'
sudo apt update
sudo apt install codium
VSCode extensions from
https://marketplace.visualstudio.com/VSCode work with Codium, too. For example, to add Python IDE functionality, install the ms-python extension:
https://marketplace.visualstudio.com/items?itemName=ms-python.pythonTried Codium in the last couple of days as a Python IDE (with the ms-python extension), and it worked very well but with less bloatware. For example, when installed the same extension,
ms-python, VScode also installed Pylance, which I didn't need, while Codium installed only the needed dependencies for ms-python.
