You could try svn and git and see which suits you. You never know - you might be a git person at heart
Being Windows based a GUI would be of big benefit. There are a few around but I would nearly always go for a Tortoise client if it's available, simply because they are robust, well proven and intergrate into the OS. You can have them all installed together since they don't interfere with each other (or anything else).
TortoiseSVNTortoiseGITOne of the hurdles to get going is having to create a project, create the repo, check in, do mode, check in, etc. But fortunately a zillion developers have given you a shortcut via github. Just go to a likely github project and checkout the source. Despite the name, github also provides svn access so you can get the same thing in the different clients for comparison.
Well, almost. Naturally, git and github are ideal for what they do there, whereas svn isn't. The upshot is that when you check out with git you download the repo as well, so repo access is very fast (unless you need to refer back to the github repo (aka the origin). With svn the repo stays at github, so any repo access (viewing the log or revision graph, for instance) involves a slow webdav transaction. Nevertheless, if you bear that in mind if gives you a good flavour.
Oh, also, if you pull the git version using the URL github supplies, you get a version of the code (plus the repo). If you do that with svn you get the entire repo contents (that is, all the branches and tags as well as the trunk), which probably isn't what you wanted. So with svn, do a repo browse to select what you want to pull down.
Edit: if you do get samples off github, bear in mind that checking any mods in will want to push them to github, which might be embarrassing. With git the changes will stay local unless you push to the origin so you should be safe, but I'd still not want to make a change and practise checking it in to someone elses live project... probably best to treat them as read only.
