new first cooked (temporary) stage4
gcc showprio.c -o showioprio
# ./showioprio
477: Best-effort 4 (default)
#define _GNU_SOURCE
#define _POSIX_C_SOURCE 200809L
#define _BSD_SOURCE
#define _SVID_SOURCE
#include <stdlib.h>
#include <unistd.h>
#include <sys/syscall.h>
#include <sys/resource.h>
#include <linux/sched.h>
#include <sched.h>
#include <string.h>
#include <errno.h>
#include <stdio.h>
int report
pid_t p
errno = 0;
long val = syscall(SYS_ioprio_get, /*IOPRIO_WHO_PROCESS*/ 1, (int) p);
if (errno)
if (errno == ESRCH)
fprintf(stderr, "%d: No such process.\n", (int) p);
return 0;
else
fprintf(stderr, "%d: ioprio_get syscall failed: %s.\n", (int) p, strerror(errno));
return -1;
long c = val >> 13;
if (c == 0)
errno = 0;
int n = getpriority(PRIO_PROCESS, p);
if (errno)
fprintf(stderr, "%d: getpriority() failed: %s.\n", (int) p, strerror(errno));
return -1;
if (n < -20 || n > 19)
fprintf(stderr, "%d: getpriority() returned an invalid scheduling priority, %d.\n", (int) p, n);
return -1;
int v = (n + 20) / 5; /* Specified as the mapping between scheduling priority and IO priority */
int s = sched_getscheduler(p);
switch (s & 0x3FFFFFFF)
case -1:
fprintf(stderr, "%d: sched_getscheduler() failed: %s.\n", (int) p, strerror(errno));
return -1;
case SCHED_FIFO:
case SCHED_RR:
case SCHED_DEADLINE:
printf("%d: Realtime %d (default)\n", (int) p, v);
break;
case SCHED_IDLE:
printf("%d: Idle %d (default)\n", (int) p, v);
break;
default:
printf("%d: Best-effort %d (default)\n", (int) p, v);
break;
fflush(stdout);
return 0;
else
int v = val & 0x1FFF;
if (v < 0 || v > 7)
printf("%d: Unknown ioprio 0x%lx\n", (int) p, (unsigned long) val);
fflush(stdout);
return -1;
switch (c)
case 1: printf("%d: Realtime %d\n", (int) p, v);
break;
case 2: printf("%d: Best-effort %d\n", (int) p, v);
break;
case 3: printf("%d: Idle %d\n", (int) p, v);
break;
default: fprintf(stderr, "%d: Unknown ioprio 0x%lx\n", (int) p, (unsigned long) val);
return -1;
fflush(stdout);
return 0;
int parse_pid
char *src,
pid_t *to
char *end;
long val;
if (!src || !*src)
return errno = EINVAL;
errno = 0;
end = src;
val = strtol(src, (char * *) (&end), 0);
if (errno)
return errno;
if (src == end || *end || (long) ((pid_t) val) != val)
if (to)
*to = (pid_t) val;
return 0;
int main
int argc,
char *argv[]
pid_t p;
int arg;
if (argc == 2 && (!strcmp(argv[1], "-h") || !strcmp(argv[1], "--help")))
fprintf(stderr, "\n");
fprintf(stderr, "Usage: %s -h | --help\n", argv[0]);
fprintf(stderr, " %s PID [ PID ... ]\n", argv[0]);
fprintf(stderr, "This reports the IO class and priority for the specified process or processes.\n");
if (argc < 2)
if (report(getpid()))
return EXIT_FAILURE;
return EXIT_SUCCESS;
for (arg = 1; arg < argc; arg++)
if (parse_pid(argv[arg], &p) || p < 1)
fprintf(stderr, "%s: Invalid process ID: %s.\n", argv[arg], strerror(errno));
if (report(p))
fflush(stdout);
it doesn't look bad.
