So do you know if keysighy is keysight is developing a scope for that range of frequency?
They are probably trying, but I doubt we will see anything like that from Keysight for the next 5 years or so.
And if they finally come out with their own 100GHz scope it probably will be a (non-expandable) 4 channel scope that only reaches 100GHz on one or two channels only.
LeCroy's LabMaster 10-100ZI can provide up to twenty 100GHz channels or up to eighty 36GHz channels. Even aside from the huge bandwidth, the LabMaster is a complete different beast than anything that is offered by Keysight or Tek.
also at the beging the guy that explain the theory said that there are company made these oscilloscope. Keysight lecroy and tektronix right? Because the top model of tek scope go up to about 30ghz
He said that there are only three manufacturers of High Speed Oscilloscopes (i.e. oscilloscopes with high sample rates of 40GSa/s or more), which are LeCroy, Keysight and Tek.
Tek has been stuck at 33GHz for some time while LeCroy and later Agilent made the jump to 65GHz and (in case of LeCroy) now 100GHz, and it's unlikely that will change anytime soon.
