By John Gulbrandsen, October 27, 2015
John.Gulbrandsen@SummitSoftConsulting.com
In order to understand the architectural differences between the various Windows platforms and the different device driver models, a historical walkthrough of the MS-DOS and Windows platforms is provided below. As will be explained, Windows 95 / 98 / ME have their roots in MS-DOS 1.0 that dates back to 1981 while Windows XP and newer platforms have their roots in Windows NT version 3.1 that was introduced in 1992. Device drivers from MS-DOS 1.0 up till Windows 10 WDM/WDF are covered.
To download a PDF version of this article, click here:
http://www.summitsoftconsulting.com/SampleCode/History_of_windows_device_drivers.pdf.
MS-DOS 1.0 MS-DOS 1.0 only supported a fixed number of device types via resident device drivers compiled into the operating system. There was no way to add drivers for custom devices without modifying the operating system binary images via patching them. Custom versions of DOS were created using the DOS OEM Adaption Kit (OAK), which was not sold to the public. The OAK contained full source code to IO.sys as well as object files and binaries to the rest of the operating system.
Applications used a CPU register - based call interface to the operating system and BIOS routines. Due to limitations in memory size and CPU speed, applications were developed in assembly language, guaranteeing the most efficient implementation.
MS-DOS 2.0 MS-DOS 2.0 introduced Installable Device Drivers which enabled a custom device to be added to an existing system. Prior versions of MS-DOS only supported a fixed set of hardware via Resident Device Drivers specifically compiled into the operating system binary image by the system manufacturer.
Since DOS and BIOS routines exposed their services via a low-level INT (interrupt instruction) interface, Installable Device Drivers were developed in assembly language. Parameters and return values were passed via CPU registers, just as in MS-DOS 1.0.
There are two kinds of MS-DOS Installable Device Drivers; Block Device Drivers and Character Device Drivers. Examples of Character Device Drivers are the console (keyboard, screen) and a modem, which both transmit a byte at a time. Examples of Block Device Drivers are Floppy Disks and Hard Disks, which transfer data in larger chunks.
Note that Character Device Drivers have names such as COM1, PRN, CON while Block Device Drivers are named A:, B:, C: etc. These device names carry through to today's modern Windows platforms. Key parts of an MS-DOS device driver are two driver routines called "Strategy" and "Interrupt" routines. These, together, execute a specific I/O operation on a particular device. Note that, despite the "interrupt" routine name, the MS-DOS device driver interface is a polling interface and is not interrupt driven. Instead, the "Strategy" routine is passed the address of a Request Header structure which specifies the specifics of the I/O operation. Immediately after, the Interrupt routine is called to do the actual I/O. The result of the I/O operation is placed in the Request Header's 'Status' field.
Installable Device Drivers are loaded into MS-DOS 2.0 (and newer) via the 'device=XXX.sys" syntax in the config.sys system file.
As an example of the simplicity of MS-DOS device drivers, note that the complete Device Driver Reference section in the MS-DOS Programmer's Reference is only 47 pages long!
Normally, a custom hardware device used I/O mapped registers, accessible via the INP/OUTP 8088 machine instructions. However, a hardware device could also be designed to allow memory-mapped register access via direct x86 MOV instructions. Such memory-mapped locations were normally jumper-configurable to avoid clashes with other expansion cards in the system. DMA and I/O locations would also be jumper configurable.
Windows 1.x Windows 1.x was merely a graphical application running on top of MSDOS. It ran on Intel 8086 CPUs or newer CPUs (80286 etc) emulating the 8086. Windows 1.x used MSDOS and the machine's BIOS for all system calls like memory allocations, file handling, graphics etc. Since Windows 1.x was running on top of MSDOS the infamous memory limitation of 640KB existed.
Drivers for the Windows 1.x platforms talked directly to the hardware via the IN and OUT assembly instructions. Since the 8086 didn't support the concept of user and kernel execution modes, no protection between different applications existed. The application that currently executed owned the whole machine since no multitasking was supported. Microsoft calls Windows executing in 8086-mode REAL mode Windows.
Windows 2.x Windows 2.x added support for the new 80286 CPU from Intel. By switching the CPU into the new 'Protected' mode, access to 16MB of RAM was made possible. When the CPU was executing in protected mode a new, more powerful, instruction set was also available.
When the CPU is running in protected mode Microsoft refers to Windows running in Standard mode. Windows 2.x could still run in REAL 8086 mode either on the 8086 CPU or on the 80286 CPU running in 8086-mode. Windows 2.x still depended on MSDOS and BIOS for all system calls such as memory and file management. To call such system services while running in protected (standard) mode, Windows had to switch the CPU back to REAL mode because MSDOS and BIOS only run in REAL mode.
Because there is no instruction for switching from protected to real mode, the CPU had to be reset for every system call. The device driver model is the same as for Windows 1.x; applications talk directly to the hardware by using IN and OUT instructions. Because Windows 2.x still was an application running on top of MSDOS no multitasking was supported.
Windows 3.0 Windows 3.0 was released in 1990. Windows 3.0 is interesting in that it's the first Windows platform that directly lends its architecture to Windows 95/98. The major improvement over Windows 2.x is that support for the new Intel 80386 CPU was added, which enabled access to up to 4GB of memory.
Windows 3.0 also used the new 'virtual machine' feature of the 80386 CPU that enabled Windows to pre-emptily multitask several MSDOS application concurrently running in MSDOS windows on the desktop. Microsoft calls this mode 'Enhanced mode Windows'. Note that only MSDOS applications were multitasked, Windows applications could only co-operably multitask in that the applications had to give away the only thread of execution to another application or else all Windows applications would stop their execution.
Since each concurrently executing MSDOS application thinks it owns the whole machine, hardware resources must somehow be shared between all the concurrently executing MSDOS applications. (Because of backward compatibility, MSDOS applications must live in an environment that looks like the old MSDOS where the running application owned the whole machine).
To support this virtualization of hardware resources, Virtual Device Drivers or VxD drivers were introduced. When Windows 3.0 is running in Enhanced mode, all applications are running in the CPUs ring 3 mode (User mode) while all VxDs are running in the CPUs ring 0 or Protected mode. User mode applications only have access to a subset of the instruction set of the CPU, especially the IN and OUT instructions are off limits for the user mode applications.
When a user mode MSDOS applications, for instance, tries to directly access hardware via IN and OUT instructions, the CPU notices that the applications does not have the rights to use these instructions and therefore throws an exception that switches the CPU into protected mode and gives the control to a VxD driver that virtualizes the device that the application tried to access.
It's the job of the VxD driver to save the state of the shared resource, switch to the state of the resource that existed the last time the MSDOS application accessed it and then return the execution to the user mode application. The user mode application knows nothing about the VxD driver's existence and therefore old MSDOS applications still can execute unchanged in Windows 3.0.
Windows 3.0 was also the first Windows platform that had protected-mode VxD device drivers. This helps structure applications since there is a clear division between user mode applications and kernel mode drivers handling the hardware. The interface for calling these VxD drivers are assembly language, parameters and return values are passed in CPU registers.
Windows 3.0 still relied on MSDOS and the BIOS for system service like memory management and file I/O. This limitation was more serious than in Windows 2.x because now all concurrently executing MSDOS applications making calls to MSDOS and BIOS had to be serialized by the system. The reason for this is that MSDOS and the BIOS routines are not re-entrant. This bottleneck in the system is one that Microsoft was trying to remove in Windows 3.1 as explained below.
Windows 3.1 Windows 3.1, released in 1992, removed many of the bottlenecks with the serialized MSDOS/BIOS calls by replacing many of the REAL mode MSDOS/BIOS routines with new routines exported by alternative VxD drivers. Since the VxD drivers are re-entrant, no serialization of system calls was necessary. These new 32-bit VxDs were also much more efficient since they did not have to execute in REAL mode 8086 mode like the MSDOS/BIOS routines. This greatly enhanced the performance of the system.
By replacing the memory management in MSDOS and the BIOS with VxD-based versions, Windows could use the new page swapping features of the 80386 CPU to support virtual memory. This was much faster than the old REAL-mode calls to MSDOS or to the BIOS to swap pages in or out of memory. Windows 3.1 however still used MSDOS and the BIOS for disk and file I/O. This limitation will be removed in the newer Windows 95 as later will be explained.
There also existed a 'Windows for Workgroups' version of Windows 3.1, which was basically Windows 3.1 with networking support added. The internal architecture is mostly the same as Windows 3.1.
The VxD device driver model in Windows 3.1 is the same as in Windows 3.0. Windows 3.1 introduced much better multimedia support than Windows 3.1 with support for both AVI video and WAVE audio playback using the WAVE APIs. Game developers however still regarded the Windows platform incapable of supporting high-performance games so they bypassed Windows altogether and ran the games directly in MSDOS. Microsoft addressed this problem by the introduction of DirectX in Windows 95 as later will be explained.
Windows NT 3.x Windows NT 3.1, released in 1992, was a completely new operating system. It was designed from scratch to support preemptive multitasking and multithreading, virtual memory, networking, etc. It was designed to be robust which meant that Windows applications were protected from each other in separate 4GB memory spaces unlike Windows 3.1 that ran all Windows applications in the same memory space. NT 3.1 also introduced the WIN32 API that allows application developers to create applications running in 32-bit mode that is much faster that the old 16-bit WIN16 applications.
NT 3.1 is completely written in C except for small parts of the scheduler and dispatcher that are written in assembly. One of the reasons for this is that NT was designed to be portable between different hardware platforms unlike Windows 3.1 that only runs on Intel x86 CPUs. NT 3.1 also introduces a completely new, cleaner, layered device driver model in which several drivers can be stacked on top of each other. I/O requests are sent between the drivers using I/O Request Packets (IRPs) as transports. An IRP is a structure that represents an I/O request. Since these new NT-style drivers are written in C instead of in assembly as in the Windows VxD case it's much faster to write NT-style drivers.
Windows NT 3.1 required an Intel 386 CPU or newer to run (or one of the other supported Alpha, MIPS or Power-PC CPUs) since it relied on the virtual memory functionality of the CPU. Most MSDOS applications are still fully supported by executing them in 'Virtual DOS Machines', which provides the MSDOS applications with an environment that makes the DOS applications think they own the machine by themselves. NT 3.1 also supports running Windows 3.x WIN16 application by providing an execution environment called WOW (Windows On Windows). The WOW is basically a single 4GB process space in which all 16-bit applications execute.
Windows NT 3.1 has the same UI as Windows 3.1. Windows NT 3.5x was basically feature updates to NT 3.1.
Windows 95 Introduced in 1995. The major news is that Windows 95 now supports the WIN32 environment introduced in NT 3.1, which allows preemptive multitasking of Windows applications. With the WIN32 model comes a protected memory model in which each application has a virtual 4GB process space. Since this needs an Intel 80386 or newer CPU, Windows 95 no longer supports the older REAL or Standard execution modes. Windows 95 also eliminates the previously described limitations of needing the MSDOS and BIOS of the machine for disk and file I/O that it now handles in new 32-bit VxD device drivers. Windows 95 also comes with full networking support built into the OS.
Windows 95 uses the same VxD device driver model as was introduced in Windows 3.0. Some of the newer device drivers have a C-callable interface in that it passes parameters on the execution stack instead of in CPU registers. New device drivers for 3rd party hardware devices can therefore be written in either C or assembly, which eases the development task considerably.
One of the big introductions in Windows 95 is plug-and-play, which automates configuration of hardware devices. This however complicates the device driver model compared to the older Windows 3.1 model; Windows 3.1 VxD drivers can still be used though.
Later version of Windows 95 (the so-called OSR2 version or OEM Service Release 2 version) brings limited USB support to Windows 95. This is not very reliable and will not be mature until Windows 98 is released. Microsoft introduces DirectX in Windows 95. DirectX is an umbrella of several APIs that attempts to attract game developers to develop high performing games running on the Windows 95 platform instead of running the games directly in DOS. The DirectX suite includes DirectDraw for high performance 2D graphics, DirectSound for low-latency sound playback and hardware accelerated sound mixing, DirectInput for joystick and force-feedback devices, Direct3D for high performance 3D graphics etc.
By using the DirectX technologies instead of writing the games to talk directly to the hardware like previously done, game developers didn't have to worry about supporting all flavors of graphics cards, sound cards and joysticks in the world, the differences between the hardware is abstracted away by a thin Hardware Abstraction Layer (HAL) that the hardware vendors instead implements for the devices.
(Post continues on next page)
