Author Topic: Handheld Precision Digital Voltage Source - IanJohnston.com  (Read 5150 times)
Offline IanJTopic starter
  • Country: scotland
  • Full time EE & Youtuber
    • IanJohnston.com
« on: January 08, 2016, 03:48:07 pm »
Hi all,
Finally!!!.......I've built up a first batch of my Handheld Precision Digital Voltage Source's and are available to purchase via my online shop.
http://www.ianjohnston.com/index.php/onlineshop
A big thanks to Dave for giving me the push I needed to go into production after featuring one of my early prototypes in his Mailbag Monday a couple months ago.
I've made quite a few changes since the mailbag and have addressed a few niggles Dave commented on, i.e.
- Better stability
- Less noise on output
- Better quality banana sockets
- More intuitive user interface
- Internal sense line to banana's allowing heavier loads without compromising output voltage accuracy
- Coax ditched in favour of heavy gauge wire
- MAX6350 Vref ditched in favour of an LM399AH = much better stability and tempco.
Below is a photo of the production unit, any questions please ask via the contact form on my site:-
http://www.ianjohnston.com/index.php/contact
FUNCTIONS & FEATURES:-
- 50mV to 10Vdc user adjustable output (4d.p’s, 5d.p’s extended, i.e. 10’s of uV’s).
- Voltage setting or ramp up/down controls via the 12 button numeric keypad.
- Soft power switch.
- Based on the industry standard LM399AH voltage reference.
- No potentiometers inside or outside.
- 18bit DAC with an accuracy/stability down in the tens of uV’s (using a PLC filter of 1.0 or higher).
- Battery voltage monitor, including low voltage warning and auto-shutdown.
- Output voltage monitor including overload / short circuit protection.
- 3” Graphics LCD (128x64 pixels).
- Atmel 328P micro-controller (uses Arduino bootloader).
- Precision chopper op-amp on final output with extra stability achieved using low tempco resistors.
- Re-calibration by the user possible via keypad/LCD and saved to flash rom.
- Battery powered.
- Battery reverse polarity protection.
- Quality Hammond 1599 case.
- Quality aluminium anodized & engraved front panel.
- Quality 4mm banana sockets.
- Single PCB integrating the analog & digital electronics, LCD, keypad & battery terminals.
- Printed manual including factory calibration/settings record supplied. Unique serial number.
Ian.
www.ianjohnston.com
Ian Johnston - Original designer of the PDVS2mini || Author of the free WinGPIB app.
Website - www.ianjohnston.com
YT Channel (electronics repairs & projects): www.youtube.com/user/IanScottJohnston, Twitter (X): https://twitter.com/IanSJohnston
The following users thanked this post: felixd
Online Vgkid
Re: Handheld Precision Digital Voltage Source - IanJohnston.com
« Reply #1 on: January 08, 2016, 09:44:08 pm »
You have done a really nice job on it.
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #2 on: January 09, 2016, 12:14:13 am »
Well outside of my hobbyist budget but a DAMN nice looking device!
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Offline HKJ
    • Tests
« Reply #3 on: January 13, 2016, 07:47:31 am »
Nice job, but I would have liked an encoder in addition to the keyboard.
And why the big margin (100mV) before it warns about output "out of tolerance"?
Offline babysitter
  • pushing silicon at work
« Reply #4 on: January 13, 2016, 08:43:49 am »
Looks good - do you want some reviews? :)
What I miss is a programmable "true" zero volt output.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline HKJ
    • Tests
« Reply #5 on: January 15, 2016, 07:38:40 pm »
Fast shipping, I received mine today.
The calibration looks good, my two best DMM's show x.0000yy (in a few cases z.9999yy) when checking the different full voltage steps. This check was done after more than one hour with power and ACAL on the DMM's/you unit (DMM's: Keysight 34470A and Keithley DMM7510). I will probably not bother doing my own calibration.
This was exactly what I hoped for, thank you.
But it would have been nice if you mailed the calibration certificate, now I will have to scan it (Paper manuals disappears rather fast).
Offline maukka
Offline jasonbrent
« Reply #7 on: January 17, 2018, 05:14:11 am »
@IanJ - Are you expecting a new batch soonish?
-j
