That is indeed a good point, the shunt resistor would be better mounter on the other side touching directly the high current path. In my case I am relying on the big plate through holes, filled with solder for the high current path which in this case is 1A maximum and will work just fine but if a higher current was used I would have to solder it on the back side as suggested.
Thank you.
