Author Topic: An Ultrasonic Range Finder Using an SRF05 and an ATTiny85  (Read 787 times)
Online hesam.moshiriTopic starter
    • MyVanitar
« on: March 25, 2022, 09:28:40 am »
An ultrasonic range finder is a useful tool in a variety of real-life and robotic applications, such as in obstacle avoidance and distance measurement systems. The ultrasonic range finder measures the distance by emitting a 40KHz pulse of ultrasonic sound that travels through the air until it hits an object, then it measures the delay of the reflected signal and sends proper commands to other units.
I used an SRF05 ultrasonic sensor and an ATTiny85 microcontroller. The distance data is displayed on a 128*64 OLED screen, both in centimeters and inches. Also, a horizontal bar graph provides a visual estimation of the distance. The MCU code was developed using the Arduino IDE.
To design the schematic and PCB, I used Altium Designer 22 and SamacSys component libraries (Altium plugin). To get high-quality PCB boards, I sent the Gerbers to PCBWay and purchased original components using componentsearchengine.com. To examine the current consumption of the circuit, I used the Siglent SDM3045X multimeter.
Isn’t cool?! So let’s get started.
    • MyVanitar
Re: An Ultrasonic Range Finder Using an SRF05 and an ATTiny85
« Reply #1 on: March 27, 2022, 12:19:17 pm »
