Author Topic: Simple open-source condenser studio microphone with a modern twist  (Read 22664 times)
Offline RFDx
Re: Simple open-source condenser studio microphone with a modern twist
« Reply #25 on: July 19, 2023, 05:08:31 am »
Very nice build. Thanks for sharing.
Is there a specific reason for the bias resistor R13 to be only 100 MOhm? R13 sets the lower cutoff frequency. Why do you need a 1GOhm bias resistor in front of the noninverting op-amp? Btw. the ground in the +/-6V supply is "artificial". There's nothing "virtual" about it :P.
Offline Spirit532Topic starter
    • My website
« Reply #26 on: July 19, 2023, 05:13:50 am »
Nope. Just off the top of my head.
Avoids DC charging of the input. Given the extremely high(many GOhm, and not particularly well characterized) input impedance of the opamp, it can cause a serious charge to build up on the input and just rail it. I've tried it without the resistor, and found that this happens.
https://en.wikipedia.org/wiki/Virtual_ground
Offline Marco
« Reply #27 on: July 19, 2023, 10:45:47 am »
The analog ground connection should ideally be in the middle of the bias string, the extra parasitic capacitance imbalances the input.
    • My website
« Reply #28 on: July 19, 2023, 10:48:32 am »
Can you illustrate what you mean by this?
Offline Marco
« Reply #29 on: July 19, 2023, 10:58:00 am »
GNDA has 47uf capacitance to GNDREF, so for AC that's what it is. Which means the bottom opamp is doing nothing, it's single ended in disguise.
    • My website
« Reply #30 on: July 19, 2023, 10:59:29 am »
It's not doing nothing, it does provide a differential signal(that I've measured), but there is an imbalance due to the way they're linked. Solving this would require adding a buffer, which would likely blow the power budget. It's already stretched pretty thin with the high impedance takeoff.
Offline Marco
« Reply #31 on: July 19, 2023, 11:33:01 am »
Voltage wise it's creating a differential signal on the XLR connector, but it's creating it from an imbalanced connection to the capsule. A voltage differential signal an sich has no real value at mic level, it's not like the mic level inputs will saturate, it's cargo cult differential. If you made the top opamp a simple unity gain buffer, removed the bottom opamp and just connected the bottom coupling capacitor directly to GNDA you would have superior noise.
If GNDA was connected in the middle of the string of bias resistors instead of the bottom, the connection to the capsule would be balanced and the differential amplification would have some justification.
    • My website
« Reply #32 on: July 19, 2023, 11:35:14 am »
It's a differential signal going down the cable for common mode immunity, there's absolutely no point in doing differential pickup from the capsule.
All audio interfaces expect a differential input by default. That's what the second opamp is for. Yes, you can ignore that and take it single ended from ground.
Offline Marco
« Reply #33 on: July 19, 2023, 11:56:37 am »
It's not the differential signal an sich which gives you noise immmunity, it's the matched impedance and a differential input on the receiving end. You can have matched impedance on a single ended output just fine.
That's why this type of differential amplification is cargo cult, it looks at completely differential signal chains and confuses an unimportant artifact (the signal being differential to a reference voltage) and confuses it for being essential. It ain't, all you are achieving by recreating the artifact is increasing amplifier noise.
    • My website
« Reply #34 on: July 19, 2023, 11:59:21 am »
It's partially true, but having it be even slightly mismatched differential will give an edge over completely single-ended. It matters less when the whole thing is shielded, and it is, but as this is an opensource project I'm expecting other, less experienced people to run into blunders like running cheaper unshielded cable, plugging it into questionable gear and such, in which case it does actually help.
Offline Marco
« Reply #35 on: July 19, 2023, 12:08:26 pm »
Better make those 47 Ohm resistors very high precision then. In audio range the output impedance of the opamp is a bee's dick.
PS. AFAICS with something modern like an OPAx828, a 0.1% difference between the 47 Ohm resistors causes more impedance mismatch across the audio range than dropping the bottom opamp.
« Last Edit: July 21, 2023, 09:39:52 pm by Marco »
Offline RFDx
« Reply #36 on: July 21, 2023, 07:11:05 am »
What I was wondering was why do you need 10 x 100 MOhm in series? You would get the same result with 200 MOhm for R13 and the opamp bias resistor.
That's right. A node that has the same voltage potential as GNDA but is not connected to it would be a virtual ground. The inverting input of U1B is indeed a virtual ground. The non-inverting input of U1B, which is connected to the (real) GNDA from the rail splitter, isn't.
Offline Zipdox
« Reply #37 on: March 04, 2024, 10:47:42 am »
Have you looked at the JLI electronics mic kits?
https://www.jlielectronics.com/diy-accessories/opa-alice-single-channel/
https://www.jlielectronics.com/diy-accessories/dc-dc-hex-inverter-pcb/
How does it compare?
Also, have you considered using two 6V zener diodes in series to create the virtual ground and 12V supply? That would result in a lower power-on time and reduce component count a bit.
Offline Valueduser
  • Put it on air
« Reply #38 on: May 10, 2024, 03:56:08 pm »
This is seriously cool, thanks for sharing!  I can't wait to make one.
Offline Md tarique anwar
  • Country: in
« Reply #39 on: August 13, 2024, 10:16:11 am »
Certainly! When a simple open-source condenser studio microphone with a modern twist, you might consider.
