Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Open Source Hardware
GM328 white screen
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: GM328 white screen (Read 4090 times)
spikeyhair
Newbie
Country:
GM328 white screen
on:
February 27, 2019, 06:30:02 pm »
I probably have posted in the wrong section so sorry about that.
However I have built one of those gm328 component testers and am getting a white screen on power up. Can some one help me out please?
Things I have tried so far:
Checking mcu with avrdude using a usbtiny ISP. The chip wouldn't give a signature so replaced it with another m328p.
Tried flashing various fw from links in this forum.
The version of product is the colour TFT gm328 with rotatory encoder and frequency generator. I got it from amazon.
https://www.amazon.co.uk/KKmoon-Transistor-Capacitance-Frequency-Generator/dp/B01HCU8VTM/ref=sr_1_3?ie=UTF8&qid=1551291890&sr=8-3&keywords=kkmoon+gm328
Hope someone can point me in the right direction with fault finding this? Hopefully I have built it correctly and its just a firmware issue?
Cheers!
Logged
Teledog
Regular Contributor
Country:
Re: GM328 white screen
Reply #1 on:
February 28, 2019, 04:03:54 am »
Definitely wrong zone, but ...are you using a decent power supply?
Those kits are infamous for white screens when using crappy batteries.
G'luck!:-)
Logged
stj
Super Contributor
Country:
Reply #2 on:
March 04, 2019, 05:55:20 am »
it's NOT a GM328, those are green backlit monochrome.
it's an "AY-AT" from some scumbag seller using the wrong description to get more search hits.
the difference is important if you want to flash it - try AY-AT firmware.
Logged
drescherjm
Contributor
Country:
Reply #3 on:
March 18, 2019, 07:39:29 pm »
I had the same behavior on first power up of my GM328 2018 kit. The problem was fixed after I resoldered the male pin header for the display.
Logged
I have BS degrees in CS and EE both in 1996. Since this time I have worked for the same medical imaging research team primarily as a programmer. Now at 47 I am trying to get back into electronics projects.
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
GM328 white screen
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
