Hi everyone,
I just release new Arduino Board. It is an open source project. Suitable for small monitoring and control application.
Hardware:
https://github.com/emrelabs/Emrelabs-PanelDuino-2x8-HardwareSoftware :
https://github.com/emrelabs/Emrelabs-PanelDuino-2x8Board Specification-Open Source Hardware
-Provided Arduino Library and example
-Embedded Arduino Pro Mini Board (5V – 16MHz)
-Embedded CH340G USB-Serial converter (USB Connector)
-2×8 Character LCD (on I2C bus)
-5 pcs user button (on I2C bus)
-LCD and all buttons use only 2 pcs pin (I2C pins)
-1 pcs user Led (D13)
-1 pcs power indicator led
-Optional external power input: 8 – 18Volt
-ICSP port
-Panel mount design
-4 pcs screw holes for easy installation
-Compact design (Dimensions: 90mm x 45mm)
DetailsA4 and A5 pins are used as I2C (for LCD and buttons). This pins only used as I2C. Also 0x20-0x21 addresses reserved. (Buttons: 0x20 – LCD:0x21)
Pictures attached.
I hope you like it
Thank you.
