Hi all,
We've done a small file converter project for our hardware and we'd like to release the source code on github as open source.
Ideally, we'd want our project to use an overall MIT license.
However, we have the following dependencies:
- Boost:
https://www.boost.org/- tinyxml12:
https://github.com/leethomason/tinyxml2- date:
https://github.com/HowardHinnant/dateWhile date also has an MIT license, the two others have less common licenses, namely the Boost License (
https://www.boost.org/users/license.html) and the zLib license (
https://github.com/leethomason/tinyxml2/blob/master/LICENSE.txt).
We've tried to read up on how to properly write the licensing section of our github repo in such a situation, but we still struggle to get it right.
Our initial thinking has been to add a section similar to below at the end of our README and then use MIT as our overall license. But we'd like to hear your thoughts on whether this is an appropriate approach or not.
### Dependencies
The project uses the following external libraries, apart from the standard library for C++17:
- [Boost]([url]https://www.boost.org/[/url])
- [tinyxml2]([url]https://github.com/leethomason/tinyxml2[/url])
- [date]([url]https://github.com/HowardHinnant/date[/url])
#### Boost license
Copyright Beman Dawes, Daniel Frey, David Abrahams, 2003-2004.
Copyright Rene Rivera 2004-2005.
Distributed under the [Boost Software License, Version 1.0]([url]https://www.boost.org/LICENSE_1_0.txt[/url]).
#### tinyxml12 license
This software is provided 'as-is', without any express or implied
warranty. In no event will the authors be held liable for any
damages arising from the use of this software.
Permission is granted to anyone to use this software for any
purpose, including commercial applications, and to alter it and
redistribute it freely, subject to the following restrictions:
1. The origin of this software must not be misrepresented; you must
not claim that you wrote the original software. If you use this
software in a product, an acknowledgment in the product documentation
would be appreciated but is not required.
2. Altered source versions must be plainly marked as such, and
must not be misrepresented as being the original software.
3. This notice may not be removed or altered from any source
distribution.
Thanks,
Martin
