I have finished an early layout of the aquisition board. Just placed the components in logical groups and took care to have straight lines for the RF-path. Nothing done to make it look more beautiful
I also realized if I want to build it within the Eurocard-Formfactor, I have to order the PCBs. With the adaptorboard, the veroboard would be too small. Putting the power supply and the control for the Filter on a different board would probably give me enough space on the boards for everything.
To shield the filters and the detector-stage, I thought about using copper foil and lego bricks as spacers to keep the foil from shorting out anything.
Using small pieces of copper soldered to the board and then putting a copper foil lid on it should work too.
To keep digital noise out of the analog system, I have separated the grounds for the analog and digital parts as much as possible. Unfortunately, one of the DACs needs to sit right in the middle of the analog area, so 2 rather long traces carrying the i2c-bus signals will run along the edge of the board to that particular chip. Fortunately, the i2c-bus is only used to configure devices that can be left alone for long periods of time (1kHz step scanning @ 1kHz RBW excluded - the Si5153 is being tuned about 1Mhz up and down in this mode while the 1st LO is tuned in 1MHz steps all other modes require only the 1st LO to be swept).
The only Bus that is constantly accessed is the SPI-Bus. To get the data out of the ADC fast enough, I need to push the clock frequency as high as possible. I hope signal integrity doesn't become an issue here. Ordering these boards isn't exactly cheap anymore: 40$ + Shipping for 5 pieces.
Any suggestions or advice about what to do and what not to do when doing the layout for ca. 30MHz fast digital signals? Do I need termination at the receiving end of the signals? Can I transport this signal via ribbon cable?
