Author Topic: OpticalShow - use optical fibers to transmit RGB leds  (Read 14039 times)
Offline green-bmsTopic starter
« on: March 31, 2023, 10:17:02 pm »
Hello, I share my latest and simple project called OpticalShow.
OpticalShow is a system that uses optical fibers to transmit the light emitted by an RGB LED matrix.
Each fiber is associated with its own LED and allows you to remote its RGB light to animate projects, such as panels, maps, artistic objects and wearables.
It consists of a 3D printed plastic mask that interfaces with an 8x8 RGB matrix, with a small hole of 0.75 mm in diameter near each single LED.
The first application I made is an animated world map, where I lit and controlled 256 cities and where I made a 32x8 matrix for scrolling texts, here's a video:
https://youtu.be/pG5Tgg9Z1Hk
Instructables project page: https://www.instructables.com/The-World-Is-Mine/
OpticalShow page: https://hackaday.io/project/189963-opticalshow
The following users thanked this post: thm_w, RoGeorge
Online RoGeorge
Re: OpticalShow - use optical fibers to transmit RGB leds
« Reply #1 on: April 01, 2023, 11:45:31 am »
Wow, the fiber optics on the backside of the map are so psychedelic!  :-+
The following users thanked this post: Raven Luni, green-bms
Offline barshatriplee
  • Country: bd
« Reply #2 on: April 20, 2023, 05:25:26 pm »
OMG! What a show! Lots of hard work. How long did it take you to complete this project?
Offline tooki
« Reply #3 on: April 29, 2023, 08:23:08 pm »
Very cool!!
What you might consider doing next time is to sand the ends of the fibers rather than just snipping them, to get a wider viewing angle without "hotspots".
