Author Topic: GM328 Transistor tester wrong battery voltage  (Read 2442 times)
Offline james3Topic starter
« on: March 10, 2019, 01:36:09 pm »
Hello,
I just finished to assemble my Transistor Tester GM328, everything seems to work fine less than the battery voltage value that is always more (when I plug 9V it says 20V, when I plug 6V it says 18V)  Any idea what's wrong ?
UPDATE:
I just found that I misplaced the 33K and the 3K3 resistance, now that they are in the right place it works perfectly
« Last Edit: March 10, 2019, 04:53:56 pm by james3 »
