Author Topic: Wordpress 3.0  (Read 22026 times)
Offline EEVblogTopic starter
Wordpress 3.0
« on: June 25, 2010, 07:42:07 am »
I couldn't resist the temptation to push the button, I just upgraded the blog to Wordpress 3.0
Looks ok, but let me know if you see anything strange.
Thanks.
Dave.
Offline Rhythmtech
Re: Wordpress 3.0
« Reply #1 on: June 25, 2010, 04:22:53 pm »
can anyone explain what wordpress is and what it can do? i've heard this buzz quite frequently. if say, i want to open up a international bussiness homepage, can i use this? how to register? or are we talking about different wordpress here?
Wordpress is a free/open source web log written in PHP. So you basically get a folder with all of the source code, you stick it on your web server and modify away. The easy part is that there are a lot of already made skins and plug ins that others have written which allow you to work on your electronics project instead of your blog.
On the flip side, it is open source so you could dive in as deep as you like and customize as much as you want.
If you were doing a professional business website, you need to look into what your needs are?  - do you need a basket purchasing application, are you going to keep user information that you could get in trouble for losing.  If you just have a website that shows what you company is, contact information, services, etc...  then wordpress could do it, but in its native form is usually setup more like blog. There are many free CSS templates that might work better for a normal business website. Wordpress requires also that you have some minor googleable skills in MySQL to setup the database for it if you set it up on your own host. Wordpress does offer freely hosted blogs, but your domain name gets a wordpress.org or something in it to do it that way.
« Last Edit: June 25, 2010, 04:24:35 pm by Rhythmtech »
Offline Simon
  • Global Moderator
    • Simon's Electronics
Re: Wordpress 3.0
« Reply #2 on: June 25, 2010, 09:28:10 pm »
another good option for a CMS (content management system as these things are all called) is Joomla! also free.
I used it for www.rotaract1070.org.uk
Re: Wordpress 3.0
« Reply #3 on: June 25, 2010, 11:10:35 pm »
Not if you have a web host who has single click install for apps like this, and most do these days. I would not use a web host that doesn't.
My web host (HostMonster) uses Cpanel and SimpleScripts which allows me to single-click install Wordpress, this forum you are using, shopping carts, etc etc.
I know nothing about about MySQL or databases, but I set up this Wordpress blog and had it working with one mouse click and waiting 30 seconds or so. Anyone can do, no skills required.
@Shafri
Wordress is a blog script/program, it's what you see when you visit www.eevblog.com It handles everything you see on that site. It allows me to easily post new blog, add menu items and pages, allows people to comment etc
It looks like this when you first install it:
http://www.jeriellsworth.com/
I've since installed a fancy interface and added extra stuff.
Dave.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Wordpress 3.0
« Reply #4 on: June 26, 2010, 02:02:16 am »
@Shafri
frankly speaking, for my own site, i dont like the way and look of the "single columned" website, i have this quite similar layout in my website, but i think i need more, a fully customizable menu and layout. for my web, i cant even freely position the menu (through the server user interface interactive setup), but for the cheap rate of $20/year, i just simply shut my mouth up.
now i saw another people showing their portfolio in their website with nice interface (and url name too... no blogsopt.com... wordpress.com at the end etc), when i found out, its the wordpress word, when i type wordpress in browser, it just direct me to some blogging site, argghhh!. and further i'm thinking of a site that can do carting, blogging, forum, link to paypal etc. i'm still working on it.... sorry... maybe off topic.
and sorry, i'm really suck at SQL, java, script etc. i dont think i'll have the time to learn such things.
« Last Edit: June 26, 2010, 02:05:47 am by shafri »
Offline Simon
  • Global Moderator
Re: Wordpress 3.0
« Reply #5 on: June 26, 2010, 06:35:37 am »
well I think simplicity is key, I hate any website with more than a central panel for content and a menu either side, for me a website should work like a book: is has pages and a menu system when you have stuff all over the place and lots of colums peple start loosing stuff unless it is correctly organized
alm
  • Guest
Re: Wordpress 3.0
« Reply #6 on: June 26, 2010, 07:03:18 am »
If it's for business and you don't have the skills/time to do it yourself, you should hire someone. They can probably do within less than an hour what might take you days.
Offline Simon
  • Global Moderator
Re: Wordpress 3.0
« Reply #7 on: June 26, 2010, 07:15:00 am »
well I set up www.sparkylabs.co.uk quite quickly with joomla! and added the virtue mart cart shopping system quite quickly, i'm no particular expert in web stuff thats why i stopped working in HTML
avrfreaks
  • Guest
Re: Wordpress 3.0
« Reply #8 on: June 27, 2010, 02:51:20 am »
I would agree with Simon, Joomla may take a little more effort but you can customize the website better. I own a portion of wordpress and 2.5 to 3.0 is just code updating and not database related. Ideally though the only reason I don't use wordpress is because it's hackable, where as joomla or drupal is not. Take for example my search engine at robo-x.net, it can search any specific websites I set, like eevblog, robo-x,3dgameman. There are more extentions to joomla + drupal and works with both your fourm (SMF) and homepage then wordpress.
  • Country: my
Re: Wordpress 3.0
« Reply #9 on: June 27, 2010, 07:41:26 am »
yup agreed with you about simplicity... but i still need freedom to do it.
great! i've downloaded the joomla, unzip it and there a whole bunch of files, template etc.... where do i start? how do i put it in my web? hehehe sorry for being a newbie on this.
Offline Simon
  • Global Moderator
Re: Wordpress 3.0
« Reply #10 on: June 27, 2010, 07:51:21 am »
Well you need to upload it  and then run the install page, you will need to setup a database from your control panel first. As dave said if your host is half on the ball they will do the 30 second install which includes setting up the database.
avrfreaks
  • Guest
Re: Wordpress 3.0
« Reply #11 on: June 27, 2010, 03:46:25 pm »
You need to upload the zip file to your website, and then extract it by the cpanel, rename the folder. ex. home/joomla or home/axim is mine. Which is in from robo-x.net/joomla or robo-x.net/axim
Go to the address you just put the folder there and follow the setup instructions. You will need to set up a database I would use the autmatic SQL wizard to do that and paste all your info back to joomla setup.
Rather I pay $3.00 a year and Mine has a automatic installer called fantastico or you can use softaculus.
Offline Simon
  • Global Moderator
Re: Wordpress 3.0
« Reply #12 on: July 07, 2010, 08:06:20 pm »
I use justhost.com but would not really recommend them, their domain registration costs a bomb so use only for file hosting, probably no worse than most for service
alm
  • Guest
Re: Wordpress 3.0
« Reply #13 on: July 07, 2010, 08:17:38 pm »
There are like a million of companies offering hosting, it's hard to not find one. How much time did you spend searching? There are several places that allow people to post their experiences. Shared should be fine, and is much cheaper that virtual or dedicated servers.
avrfreaks
  • Guest
Re: Wordpress 3.0
« Reply #14 on: July 07, 2010, 08:24:26 pm »
need help... where can i rent for a server or webhosting that i can put in and run this joomla thing? i dont have any personal server computer ???
I specifically use: Bison Hosting which is unlimited everything (see below) and includes Softaculous(Automatic PHP App Installer) + Fantastico (Auto Joomla Installer) - @ $2.99  per year.
http://cgi.ebay.com/2-Year-Unlimited-Web-Domain-Hosting-5-99-2-Year-/280431395848?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item414b038408#ht_5480wt_1137
http://www.netenberg.com/fantastico.php - A
www.softaculous.com/ - B
Offline Simon
  • Global Moderator
Re: Wordpress 3.0
« Reply #15 on: July 07, 2010, 08:46:28 pm »
justhost is not bad but they have a lot of marketing shit
  • Country: my
Re: Wordpress 3.0
« Reply #16 on: July 07, 2010, 10:01:42 pm »
thats why, i'm confused, i'm afraid getting in the wrong direction as i already have a website (www.soasystem.com) which pretty much only for displaying something and some stupid blogging, even designing the site is limited to some stupid template. i want to be able to control down to code/script/html level including MySQL (database ???) etc. i want to have a space in the net, when i logged in as admin, i can treat the space just like my local hard drive like admin/myfilehere... admin/mypicishere, etc etc... and most importantly, upload the joomla and when somebody typing my domain name, from another planet, its running and providing them with payment option, paypal etc for doing online business. i found this, its my local country site, is it suitable? for me? = http://www.malaysiahosting2u.com/hosting.html
i dont want the host, after i register, will limit me to something, i cannot do this, i cannot do that, i cannot store any database or customers password etc. i cannot run certain script or program. ???
and i cannot setup a forum like this "magnificent" EEVBlog!
« Last Edit: July 07, 2010, 10:14:25 pm by shafri »
alm
  • Guest
Re: Wordpress 3.0
« Reply #17 on: July 07, 2010, 10:45:14 pm »
Sorry, I missed all that explanation about what you wanted when I read your original question.
It does help if the hosting provider is geographically close to the customers, since that means faster response (which is why big sites like Google have servers all over the world), so if your customers are mainly from Malaysia, it's probably not a great idea to use a US hoster, although that would be cheaper. Do check if it's actually hosted in Malaysia, and they're not just reselling US hosting, otherwise you might as well do it in the US yourself. From a quick glance at the specs, the do appear to support PHP/MySQL, so most CMS's should work. They appear to offer some sort of forum, but no easy setup for a CMS as far as I can see, so you do need some knowledge to set it up. The price (under US$ 20 per year) does seem a bit low, although domain registration adds an extra $14, and it's only if you pay for two years (I wouldn't without any experience). Don't have any personal experience with that hoster, can't help with that.
avrfreaks
  • Guest
Re: Wordpress 3.0
« Reply #18 on: July 07, 2010, 11:47:32 pm »
thats why, i'm confused, i'm afraid getting in the wrong direction as i already have a website (www.soasystem.com) ...  and most importantly, upload the joomla and when somebody typing my domain name, from another planet, its running and providing them with payment option, paypal etc for doing online business. i found this, its my local country site, is it suitable? for me? = http://www.malaysiahosting2u.com/hosting.html
If you go with is hosting provider realize that it is limited to 4GB-20GB, no fantastico, no automatic scripts.
  • Country: my
Re: Wordpress 3.0
« Reply #19 on: July 09, 2010, 05:40:04 am »
so far, what my instinct can tell is that i'm not going to use all the 4GB, i dont think will put many fancy fancy big videos, multimedia etc, only some textual or encrypted database inside (and of course! some static bitmap or jpeg images), but.... i dont know, not really sure.
no automatic script? what do you mean? i need something like... i upload the index.html, then it is the welcome screen for my site, inside there i can put anything script, java, flash etc that will in turn be run and popped out in my site. isnt that it should be like that?
@alm = thanx, i was not aware of the hoster's geographic thing. as a starter, i think $20/year is suitable for me, then it will depend on how it will progress, but i dont want a cheapy that limit me to some b*llsh*t, that i cant run what i want to run. maybe asking the support from the hoster will help, i already did yesterday, still waiting for the answer.
« Last Edit: July 09, 2010, 05:42:14 am by shafri »
avrfreaks
  • Guest
Re: Wordpress 3.0
« Reply #20 on: July 09, 2010, 05:59:25 am »
You can check out the link I gave you above. I run all my site from this good hosting company and 24/7 live support.
  • Country: my
Re: Wordpress 3.0
« Reply #21 on: July 09, 2010, 12:32:37 pm »
thanx freak! err... avr. i just noticed, but... linux? i'm a sh*t in it! its interesting... if i register in, will you help me if i got stucked somewhere? i'm a total blind in this. and one more thing... does it provide a domain name like myname.com? i want to transfer my existing .com to this hoster.
« Last Edit: July 09, 2010, 12:37:02 pm by shafri »
Re: Wordpress 3.0
« Reply #22 on: July 09, 2010, 01:11:44 pm »
Watch out for the "unlimited everything" plans, it's almost always bullshit.
I use HostMonster.com for all my sites including this one and it is supposed to be unlimited everything. But I find myself running into all sorts of limitations.
The latest one is the number of files on the server. Over 50,000 files and they won't do the automatically daily backup and may close your account.
I've hit this wall now and may have to get another host for my other sites. The forum image attachments are actually now the largest number of files in a directory on my server.
You can't store any non-website related files either (no using it as a personal backup system), and you are actually limited in peak bandwidth even though they don't mention it, so my server gets throttled a few times a day etc.
As I said, make sure you get a host that provides SimpleScripts or Fantastico or some other system. I installed this forum with a single click.
Dave.
Offline Simon
  • Global Moderator
Re: Wordpress 3.0
« Reply #23 on: July 09, 2010, 01:17:48 pm »
Basically you never get free cake, I run all my stuff of just host but I'm that small that no limitations are evident as of yet
  • Country: my
Re: Wordpress 3.0
« Reply #24 on: July 09, 2010, 01:36:30 pm »
ooo. like that aaa? thanx for d advice. i surfed the bison site, the basic cheapest is $19.99/year, 2GB only, no fantastico, no simplescript. but in ebay the avrfreaks gave is $5.99 for 2 years, got fantastico and all bunch of the stuffs that dont read in my mind. avr? any advice? do you have your own name.com? carting etc?
@simon: maybe dave has bought a cake for a decent price, that the seller said it has every peanuts in it. but it turned out, it only has couple or two.
« Last Edit: July 09, 2010, 01:39:50 pm by shafri »
