Author Topic: WARNING: Compromised Accounts  (Read 33680 times)
Offline EEVblogTopic starter
« on: February 20, 2024, 11:42:15 pm »
There has been a recent spate of existing forum accounts being compromised by spam bots.
Presumably they had their details stolen and reused passwords?
So just a reminder to make your password unique and/or use the 2FA security feature.
« Last Edit: February 21, 2024, 02:32:24 am by EEVblog »
The following users thanked this post: PeterG, stryker, xrunner, Kean, cosmicray, 2N3055, TERRA Operative
Online xrunner
  • hp>Agilent>Keysight>???
Re: WARNING: Compromised Accounts
« Reply #1 on: February 21, 2024, 12:05:50 am »
Yea I have seen a lot of them recently. Therefore I just set up 2FA here and the process was painless and worked.  :-+
Online KE5FX
    • KE5FX.COM
« Reply #2 on: February 21, 2024, 12:43:14 am »
How does one brute-force a password?  Don't you lock the account out for X hours after Y unsuccessful attempts?
Usually, "brute forcing" a password involves a stolen password database file, potentially from some other site where the user with the same name used the same password.
Offline coppercone2
« Reply #3 on: February 21, 2024, 12:44:29 am »
the meat of our dead crew members is being turned into spammer-advertiser cyborgs
can the morgue be locked?
« Last Edit: February 21, 2024, 12:49:33 am by coppercone2 »
Offline MLXXXp
« Reply #4 on: February 21, 2024, 01:39:07 am »
Any chance support for FIDO hardware security keys for 2FA (Yubico, Google Titan, etc.) could be added?
« Reply #5 on: February 21, 2024, 02:31:36 am »
Yes, probably more likely to be the owner had their account compromised and shared a password.
« Reply #6 on: February 21, 2024, 02:33:20 am »
If there is an SMF plugin that does that then I'm happy to install it, I use hardware keys myself. But last I looked there wasn't.
Offline coppercone2
« Reply #7 on: February 21, 2024, 03:29:38 am »
arent all these accounts long dormant?
« Reply #8 on: February 21, 2024, 04:11:41 am »
Haven't checked them all, but from what I've seen, not recent posters. But they were still active accounts with legit posts.
Online CatalinaWOW
« Reply #9 on: February 21, 2024, 06:18:40 am »
Do you send notifications to those who have been compromised?
Offline Zoli
  • Grumpy old men
« Reply #10 on: February 21, 2024, 06:54:07 am »
I've checked(other forum, so is a widespread issue) some of the compromised e-mails: typically pawned in 10+ data breaches; add bad password hygiene in the mix, and you have the current situation.
Edit: since I've seen the spam posts(similar to the other location), I recommend to Dave, to use the forum censorship to change the *.site advertisement to something else(spam would be an idea).
« Last Edit: February 21, 2024, 06:58:29 am by Zoli »
Offline magic
« Reply #11 on: February 21, 2024, 08:25:21 am »
"Brute forcing" means repeatedly trying random passwords without any idea which one could be right.
I tested this forum during the last wave of compromised account spam. A few failed login attempts lock the account for a few minutes and during this time even the correct password doesn't work. So true brute forcing is slow and unlikely to succeed.
These compromises are caused by using "well known" login/pw combinations, usually obtained from other hacked websites. If you know that some login had a particular password on another site, it's a no brainer to check if the same password also works here.
« Last Edit: February 21, 2024, 08:27:12 am by magic »
