Author Topic: Saleae logic  (Read 7423 times)
Offline DavidDLCTopic starter
Saleae logic
« on: February 22, 2010, 09:49:01 pm »
Dave, this can be a review for future posts:
http://www.saleae.com/logic/features/?q=i5&gclid=CLGD7uf1hqACFQ49Zgodhm6XsA
I saw the price and somehow got interested, if you can get you hands on one of those and give it a review it will be great.
Offline armandas
  • Country: jp
    • My projects
Re: Saleae logic
« Reply #1 on: February 22, 2010, 10:46:32 pm »
Dave has done a video on logic analysers:
http://www.eevblog.com/2009/11/16/eevblog-44-part-1-logic-analyzer-tutorial/
http://www.eevblog.com/2009/11/16/eevblog-44-part-2-logic-analyzer-tutorial/
Now check the specs and decide for yourself. You can also try their software.
Offline TheDirty
Re: Saleae logic
« Reply #2 on: February 22, 2010, 11:16:20 pm »
I have a Saleae.  It's pretty useful.  I was going to mention that Dave's previous blog pretty much covers these in general, though he only passingly mentions this type that doesn't use a buffer, but real time streams over USB.  It's good for hobby work and I do a lot of interfaces with SPI, I2C, serial, and parallel data streams.  The only limitation I've had is that 8 channels was not enough for a 8bit parallel data interface with 4bit address that I've had to do.
Mark Higgins
Offline rossmoffett
Re: Saleae logic
« Reply #3 on: February 23, 2010, 04:07:54 am »
Probably if you want Dave to review something the best strategy is to beg the retailer, not Dave, because if I were him I wouldn't want to go off buying new products all the time to review, or ask for them for free.
Tell them you'll buy it if he approves, and see where that goes.
ArcAttack - A group of musical Tesla coil performers with semi-regular blog updates.
Offline Ferroto
Re: Saleae logic
« Reply #4 on: March 04, 2010, 04:35:31 pm »
I've been seeing adverts for that all over the place. It would be nice if it had a display so it could give realtime measurements at clock rates faster then that of the USB connection to the PC also a display would give it a degree of mobility. and umm it needs more then 8 channels :P
Offline charliex
  • Car Hacker
Re: Saleae logic
« Reply #5 on: March 04, 2010, 06:20:53 pm »
the intronix has 34 channels and a buffer http://www.pctestinstruments.com/
also lookup the sump LA for a cheap one.
Offline rossmoffett
Re: Saleae logic
« Reply #6 on: March 05, 2010, 03:52:02 am »
Recently on hackaday an even better model was introduced:
http://hackaday.com/2010/02/28/open-source-logic-analyzer-2/
Open source, even.  You can probably use it as an FPGA development platform.
GeekGirl
  • Guest
Re: Saleae logic
« Reply #7 on: March 05, 2010, 09:12:17 am »
This is the unit that I use at home. It works very well for general uC debugging and serial stream debugging :)
Offline charliex
  • Car Hacker
Re: Saleae logic
« Reply #8 on: March 05, 2010, 05:46:34 pm »
Me too Kat, It works with CAN bus and slower memory interfaces which is primarily what i use it for.. i usually go for it first since i really like the UI
For the newer version of the sump LA from dangerous prototypes/gadgetfactory. It's actually less capable than the original which has more channels, but its also more expensive.
I've got a spartan 3A sump and it works well, i got the DP one on preorder from seeed just to see how well it works. You can never have enough logic analysers ! :)
