Planned obsolescence appears less prevalent in products today.
It wasn't so back in the 1950s-1980s when technology wasn't changing as fast as it does now, planned obsolescence was fairly obvious, but many "tech-knowledgeable" people could work around those product life cycles.
For example, in the 1950s, as Tandy suggest, a simple incadescent light bulb dimmer [ rheostats in those days] would prolong a light bulbs life, later in the 1990s triac based dimmers did the same thing. I have incandescent light bulbs in my home over 20 years old because they are powered by triac dimmer circuits and I use a simple engineering rubric of derating the item, so I run 100 watt light bulbs at 50 watts or less. The dimmer circuits also prevents surge currents which cause most incandescent bulb deaths.
Using the same rule, buying industrial or commercial grade products provide longer life than consumer grade because they were designed for higher duty cycles, typically those were kitchen appliances like blenders, washers, etc., or cleaning appliances like vacuum cleaners. The price differences between an commercial vacuum cleaner more than made up by its very long lifepsan and endless spare parts.
When a product has a customized consumable such as printer cartridges, toothbrush heads, batteries, filters, etc., they become obsolete when those consumables cease to be made, often third party industries grows around the fault to supply that obsolete part such as with iPhone batteries, LCD screens, and printer cartridge re-fillers.
Items in recent past easily outlive their functionality to show not every product is built for planned obsolescence, even in the consumer sphere: PCs, CD/DVD players, POTS telephones, analog TVs, etc.,.
In electronics, DMMs, analog oscilloscopes, and a lot of true HP T&M gear, are extremely durable and are many decades old still working, or can be made working with simple repairs but are obsolete in industry due to speed, network incapable or that it doesn't support new safety regulations [ e.g. CAT ratings for DMMs.]
Apple's iPhones epitomize "planned obsolescence" today by fielding a new feature set with each new model, but its not really 'obsolete' since the older model still works compared to the incandescent light bulbs of the 20th century.
