Author Topic: Micro... Radar detector for when the fiberglass flat panel van shows up.  (Read 3863 times)
Offline vigsgbTopic starter
Create a micro radar detector for when that fiberglass sided van shows up outside your house.
This is in reference to an amp hour episode in which they talk about spy gadgets that are powered via radar.
« Last Edit: January 30, 2014, 02:29:05 am by vigsgb »
Online Fraser
Re: Micro... Radar detector for when the fiberglass flat panel van shows up.
« Reply #1 on: January 30, 2014, 02:06:32 am »
Fibreglass van outside your house ? Radar detector ? All sounds very 'unusual' . Are you sure you have used the correct terms here ?
I am a UK DTI certified Radar engineer and have not seen them used against peoples houses !
Offline GeoffS
« Reply #2 on: January 30, 2014, 02:24:04 am »
A bit confusing with out a reference to the recent Amp hour broadcast.
« Reply #3 on: January 30, 2014, 02:26:40 am »
You have to listen to the latest amp hour episode as they talk about the leaked spy gadgets that use radar to power up inductive type spy devices.   Fun episode.
Offline zapta
« Reply #4 on: January 30, 2014, 05:16:40 am »
Don't know if it was mentioned but this is an old technology, more than 50 years old.
http://www.spybusters.com/Great_Seal_Bug.html
Online Fraser
« Reply #5 on: January 30, 2014, 10:27:01 am »
@Geoffs,
Thanks for the explanation. All clear now.
If this is a serious question by the OP...... Please relax and get on with your normal life. Unless you are a potential threat to the national security of the host country, you are of no interest. Please remember that such organisations have finite staff resources and budgets, they focus their attention where it is needed.
Offline GiskardReventlov
  • How many pseudonyms do you have?
« Reply #6 on: January 30, 2014, 05:53:03 pm »
I am not a UK DTI certified Radar engineer and have not seen them used against peoples houses !
Online Fraser
« Reply #7 on: January 30, 2014, 06:54:38 pm »
 ;D
Online Fraser
« Reply #8 on: January 30, 2014, 07:19:06 pm »
Mind you my neighbours may need a Radar detector.... I have at least five Raytheon small boat RADAR sets in my shed awaiting my attention. I also have a lovely open scanner long Range RADAR that I must get around to firing up  ;)  I used to be a RADAR specialist but that was some time ago, so I will refresh my brain cells on the little Raytheon units  :)
I also understand the technology that the OP appears to fear. My honest comment. Please stop concerning yourself about this technology, unless you are one of the 'bad guys'. If you are a 'bad guy', be affraid, very affraid  ;)
Edit: some more waffle removed
« Last Edit: January 30, 2014, 07:29:07 pm by Aurora »
« Reply #9 on: January 30, 2014, 10:24:02 pm »
The op is not worried about this technology just curious..  would be interesting to have a detector to see how prevalent those types of signals are found around a city.  Maybe even cooler would be some sort of detector that could tell you what types of signals are flying around and you could then choose what type you want to detect.
Online Fraser
« Reply #10 on: January 30, 2014, 10:33:12 pm »
Welcome to the world of TSCM (Technical Secuirty Counter Measures)  ;)
