How do you add to the map?
Try this:
h.ttp://maps.google.com/maps/ms?ie=UTF&msa=0&msid=112679702572119643834.000496b60853e165a9a9a
without the period
So you need a Google account?
Pity.
Oops, didn't realise the forum converted the link into an actual map!
Looks like anyone can edit other peoples pins which seems insane!
Someone accidentally moved the pin I placed.
Anyone know how to stop that?
Dave.
Dave.
Don't ask me how but I moved Trafalgar to Vanuatu oops. LOL I can't move it back!
UPDATE: Moved it back not sure it's in the correct spot
Ooops
I moved someone's pin in Malaysia. That's crazy that you can move other people's pins!
Edit: I think it was in Malaysia originally, but not sure anymore... I was zooming in when it happened and ended up in the Bering Strait. WTF?!? It's Mats' pin, whoever you are. Sorry!
Done. To put yourself on the map:
1. Open the EEVBlog community map:
http://goo.gl/G7hUc2. Type in your location to the "Search Maps" bar and press Enter
3. Click your location marker and select "Save to...", then choose the EEVBlog map.
done and done, im on the map, the second dot on NZ with my forum name
Added, and found out that someone else in my town watches.
1. Open the EEVBlog community map: http://goo.gl/G7hUc
3. Right click your location marker and select "Save to...", then choose the EEVBlog map.
Treid that, but eevblog doesn't appear in the list of maps - I do see 'Sofian Jafar'....
That's where I put myself, Sofian Jafar
Strangely enough there is not yet someone posting their location on Antarctica or on an ocean
I'm down on there now, very generally.
