Author Topic: Expanding - Hopefully  (Read 31482 times)
Offline EEVblogTopic starter
Re: Expanding - Hopefully
« Reply #100 on: July 14, 2021, 10:40:51 am »
Just a quick note -- TME are offering low smoke jacketed installation grade cable in 8 strands G.652 SMF at 0,80 € per meter in 100m lengths -- so, it is basically the same as Cat 6. The price difference is that a splicer costs more than a LSA-Plus tool  :-DD
and you need equipment both ends also.
« Reply #101 on: July 14, 2021, 12:04:04 pm »
Settlement tomorrow!
Although it's unlikely I can do anything this week with it as I'm busy with other personal stuff.
Offline Brumby
« Reply #102 on: July 14, 2021, 03:46:20 pm »
Celebrate with a Perrier!
« Reply #103 on: July 15, 2021, 01:55:29 am »
I might have time for a walkthrough video today if I get the keys.
The exchange is happening at 12:30pm today and probably involves two trenchcoat wearing solcictors exchanging keys and bags of cash in a dark underground carpark.
They'll call me when it's done.
Now with two storge units and an office, I think I might change the locks to a single key for convenience.
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #104 on: July 15, 2021, 02:12:56 am »
 ;D
Ha. If experience has taught me anything it will be a couple of secretaries doing the actual conveyancing.
iratus parum formica
« Reply #105 on: July 15, 2021, 02:34:07 am »
That'll be $1800 please.
« Reply #106 on: July 15, 2021, 05:08:47 am »
The following users thanked this post: hans
Offline Ed.Kloonk
« Reply #107 on: July 15, 2021, 05:12:37 am »
First
Offline Ed.Kloonk
« Reply #108 on: July 15, 2021, 05:25:52 am »
That pole is perfect for keeping the gimp tied up.
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #109 on: July 15, 2021, 07:16:49 am »
Nice.   :-+
In regards to that big board, If permissible I would dynabolt a 90 x 45 horizontal pine stud to the wall then fix a few hinges and add a couple of hinged legs, this could act as a foldup assembly or packing bench if required. Also, if you are going to keep stock in that store room check whether it will be covered under your insurance policy. If you are running cabling for the network also consider whether you need to run some additional security cabling as well.
« Reply #110 on: July 15, 2021, 07:32:49 am »
It's mine, I hereby authorise!  :-+
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #111 on: July 15, 2021, 09:16:31 am »
Re internet - just turn up with a  high-vis, hard-hat and a roll of cable - nobody's gonna notice another wire in the ducting.
Is the power metered seperately? If not, you did say it was next to your parking space - free charging!
Day Job: Mostly LEDs
Offline Ed.Kloonk
« Reply #112 on: July 15, 2021, 09:32:03 am »
^ He's right, you know.
The only way to upset the apple cart is to park in somebody's God given car spot.
« Reply #113 on: July 16, 2021, 05:38:00 am »
Not metered, same as my bunker.
Actually not right next to my parking spot, it's quite a few spots over, not something you could string up an extension cord to unfortunately. As Ed said though, parking spots are god given.
There are a few power points scattered around the carpark.
There is actually no cable trough running to the storage unit, power and lights are through the concrete slab roof. So any comms cable will have to be run either in a new conduit or maybe along the top of the air ducting that conveniently comes from the MDF room.
« Last Edit: July 16, 2021, 05:50:56 am by EEVblog »
« Reply #114 on: July 16, 2021, 11:37:29 am »
Yeah but who'd notice another cable clipped to the wall...
« Reply #115 on: July 17, 2021, 03:34:06 am »
All those who know I drive an EV. I wouldn't get away with installing a 20m extension cord across the roof.
Offline Ed.Kloonk
« Reply #116 on: July 17, 2021, 04:28:49 am »
I dunno man. With the right amount of vans with orange flashing lights. Some strategiclty placed witches hats. For good measure, have a dude with a clipboard and a high vis vest that reads C*v*d Inspector.
Random ppl be like ...----------->>>>>>>>>>>! [poof!]
Offline PlainName
  • Country: va
« Reply #117 on: July 17, 2021, 04:35:03 pm »
Now's your chance to develop wireless power charging and show those scammers how it should be done.
The following users thanked this post: Towger
« Reply #118 on: July 18, 2021, 06:06:00 am »
Inspection of the cable run.
« Reply #119 on: July 18, 2021, 10:41:45 am »
I'd imagine there would be plenty of spare pairs in those multicore phone cables running down to the MDF room
Offline PlainName
  • Country: va
« Reply #120 on: July 18, 2021, 11:01:24 am »
Pneumatics. No-one else is using that air vent so you could stick a speaker at one end and microphone at the other and play modem warbling sounds. Bandwidth not so hot, but think of the YouTube videos you could do!
« Reply #121 on: July 18, 2021, 12:31:42 pm »
I only have 12 or so spare pairs in my lab.
« Reply #122 on: July 18, 2021, 03:05:10 pm »
So if they come out in the MDF room, that saves the hardest part of the cable run, through those full-up floor holes.
Offline Fubawuba
« Reply #123 on: July 18, 2021, 08:44:04 pm »
As suggested before, have a look at fiber optical connections. It's more affordable than you think.
You could for example use 2x media converter (RJ45<->SFP Cage) + 2x SFP(+) module, + fiber cable.
The distance is not a problem and the fiber cable (it's usually a twin cable with TX+RX fiber) is very thin (usually +/- 2mm sleeve per fiber) and quite flexible, but it's also a bit fragile (bend radius, thin sleeve, etc.), so you might want to put it in a PVC pipe or tube for additional protection.
You can find fiber twin-cable even on large spools for extra long length, but attaching LC connectors your self is complicated (LC connectors are the most common type of fiber connectors for home & garden use :)) so it's better to use a prefab cable.
Common combinations:
For short range (max range <550m, but also limited by module RX sensor sensitivity and TX output power) you can use multi-mode (850nm) SFP(+) modules with OM3 or OM4 fiber with LC connectors.
For long range you can use single-mode SFP(+) modules (usually 1310nm) and OS2 fiber with LC connectors.
You can find very affordable SFP's in the 100M-10G range.
Example:
2x 1G TP link media converter + 2x FS.com 1G SFP module of choice (for example 1000BASE-SX) + OM4 fiber twin cable with LC connectors (TX+RX)
With the fiber cable in place you can always upgrade to higher speeds by replacing the media converters and SFP modules (as long as it has LC connectors and is suitable for the fiber you used).
In any case this kind of solution will be more reliable and will have a faster connection than any kind of wireless connection (especially in a building full of metal) and it's easier to handle than RJ45 network cable (with a prefab cable, in your situation).
« Last Edit: July 19, 2021, 04:20:31 am by Fubawuba »
Online Monkeh
« Reply #124 on: July 18, 2021, 11:48:39 pm »
So approximately 15m to that cupboard. About 3.4m per floor (200mm per block x 17), or 16m down to the correct floor. I reckon about 25m to the 90 degree on the duct, maybe another 10m from there to the bunker wall. Your 70m guess isn't too far off the mark. I'd guess 80m for a real cable run. Copper should be fine, although I doubt they'll want to just run it on top of the duct - but that route will probably be fine to follow.
I would still run fibre, but that's me. Also, as to the 'box on both ends' argument - you may as well have wifi down in the bunker, so no extra box needed down there (APs with SFP slots for fibre are readily available).
« Last Edit: July 19, 2021, 12:07:31 am by Monkeh »
