I disagree Dave. I'm sorry, but if you keep telling me it's just my opinion that a forum is a record of the interactions of members for posterity that should not be tampered with, except in the case of rule violations, I'm going to keep telling you you are just plain wrong.
Fine, you've had your say.
You really do not want a forum at all if you think people should be able to delete and edit posts for as long as they want to.
Don't tell me what I do and do not want, I'll make up my own mind, thanks.
Anyway, I do think we both have an abundant supply of testosterone. ![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Nope, you have a fixed opinion that simply will not change. But worse, you think your
opinion is actually the be-all end-all right answer. Like there is only one obvious right answer to a question that is clearly (IMO) quite subjective.
That kinds of thinking works on an the atheist forum you run, when things are either true or they are not true, but it doesn't cut the mustard in this instance I'm afraid.
