I sometimes do some network admin for a local organization, they have a 48-port Dell switch and two 48-port patch panels that are gradually filling up as they expand. They now need a second switch identical to the first and in most network installs I have seen the switches are grouped together at the top, however, these Dell units run hot and I already have a 150mm fan cooling the rear of the case. So, do I.........
a) Mount the two switches together like everyone else does and hope that the heat does not become a problem.
b) Mount the two switches at the top but with a 1U gap between them for ventilation, this sounds ideal but it will mean purchasing A LOT of longer patch cords. The fan will probably be able to cool them like this but I am not sure.
c) Mount one switch at the top, the patch bays in the middle, and the second switch at the bottom. I then need to get creative and find a way to mount a fan to cool the second switch.
Please explain your answer.
