Hello my friends, i bought it on eBay, for interest(explore), with "parts, noHDD" condition.
Found and install windows OS and software, but acquisition board is locked by password.
Board run on VxWorks 5.5. software(firmware).
Connecting by the debug port i can see, and change boot configuration.
I already boot from internal NAND, External FTP. and try many other tricks))
But it goes with C interpreter language and i dont know command syntaxis to reset configuration password.
Anybody can help me with any methods?
The last chance is to corrupt NAND files, to emergency boot from FTP.. but it is so risky..
Attached the booting log from terminal here :
FTP Boot: (i found zipped booting files in software package)
VxWorks System Boot
Copyright 1984-2002 Wind River Systems, Inc.
CPU: Intel 81342
Version: VxWorks5.5.1
BSP version: 1.2/4
Creation date: Aug 14 2008, 14:18:27
Press any key to stop auto-boot...
0
auto-booting...
boot device : gei
unit number : 0
processor number : 0
file name : image0/vxWorks
inet on ethernet (e) : 192.168.111.110
host inet (h) : 192.168.111.111
flags (f) : 0x80
other (o) : gei
Attached TCP/IP interface to gei0.
Warning: no netmask specified.
Attaching network interface lo0... done.
Loading... 5713472 + 1809528
Starting at 0x10000...
Attached TCP/IP interface to gei unit 0
CPU: Intel 81342 Rev. C1
SDRAM: 128 + 384 MB
Error opening vxWorks2
ep2s90.rbf: errno = 0xfffffff3
FPGA: (null) 0 0, 00:00:00
muxDevLoad failed!
bullwinkle=0
CPLD readback
readback: 1
FPGA readback
PCI vendor=0xffff, device=0xffff: 0
readback: 0
HwTest result code:5
Aux PHY readback
PHY PCI vendor=0x8086, device=0x1078: 1
Aux PHY EEPROM checksum
PHY EEPROM checksum: 1
Mgmt PHY readback
Mgmt PHY EEPROM checksum
NUT PHY readback
id1=0x141, id2=0xcc2: 1
System Monitor readback
ADM1024_0 ID=65: 1
ADM1024_1 ID=65: 1
ADM1024_0 readback: 1
ADM1024_1 readback: 1
Fans tach measurement
-> CPU Fan rpm=12272: 1
Fan 1 rpm=7758: 1
Fan 2 rpm=7894: 1
fan tach: 1
Dual Core
-> IMU response timeout: 0
POWER-ON SELF TEST ***FAILED***
0x7db36e8 (tNetTask): duplicate IP address 00000000 sent from ethernet address 2
8:18:78:ff:f2:5c
Reading Phase 2 format EAP settings.
Data abort
Exception address: 0x0024792c
Current Processor Status Register: 0x20000013
Task: 0x7c9d134 "tMain"
NumProtocols=1070 LocalIndex=1,1072
MFlowClient::changeProcessingState() status timeout
8:18:78:ff:f2:5c
8:18:78:ff:f2:5c
*** Task: tMain suspended - watchdog will reboot system!
8:18:78:ff:f2:5c
8:18:78:ff:f2:5c
8:18:78:ff:f2:5c
Normal, standard, boot from NAND:
VxWorks System Boot
CPU: Intel 81342
BSP version: 1.2/4
0
auto-booting...
boot device : nand
unit number : 0
flags (f) : 0x8
other (o) : gei
Loading... 5234108 + 1133236
Instantiating /ram as rawFs, device = 0x1
Formatting /ram for DOSFS
Formatting...Retrieved old volume params with %38 confidence:
Volume Parameters: FAT type: FAT32, sectors per cluster 0
0 FAT copies, 0 clusters, 0 sectors per FAT
Sectors reserved 0, hidden 0, FAT sectors 0
Root dir entries 0, sysId (null) , serial number 770000
Label:" " ...
Disk with 64 sectors of 512 bytes will be formatted with:
Volume Parameters: FAT type: FAT12, sectors per cluster 1
2 FAT copies, 54 clusters, 1 sectors per FAT
Sectors reserved 1, hidden 0, FAT sectors 2
Root dir entries 112, sysId VXDOS12 , serial number 770000
Label:" " ...
OK.
Adding 24707 symbols for standalone.
SDRAM: 128 + 384 MB
Default path: /nand0/flash/image0
Loading... 731456 + 243572
Starting at 0x20010000...
FPGA: Jun 20 2008, 12:31:09
-> PCPort IPAddr: 192.168.111.110
bullwinkle=1
CPLD readback
readback: 1
FPGA readback
PCI vendor=0x1172, device=0x4: 1
readback: 1
Aux PHY readback
Mgmt PHY readback
NUT PHY readback
ADM1024_0 ID=65: 1
ADM1024_1 ID=65: 1
Environmental voltages
ADM1024_0 Vcc=189 (lo=182, hi=201): 1
ADM1024_1 Vcc=189 (lo=182, hi=201): 1
battery V=180 (lo=95, hi=228): 1
5V=190 (lo=182, hi=201): 1
3.3V=125 (lo=116, hi=129): 1
2.5V=189 (lo=182, hi=201): 1
1.8V=128 (lo=121, hi=134): 1
1.2V=90 (lo=87, hi=96): 1
CPU 1.2V Vcc=86 (lo=81, hi=89): 1
DDR 1.8V Vdd=127 (lo=121, hi=134): 1
DDR 0.9V Vtt=63 (lo=60, hi=67): 1
CPU Fan rpm=12162: 1
Fan 1 rpm=7758: 1
Fan 2 rpm=7894: 1
fan tach: 1
Dual Core
IMU response 0 in 1 ticks: 1
POWER-ON SELF TEST PASSED
ProtDir: static protocols=2021 custom protocols=0
IMC initialized on port 1695
PassThruInteg::startPktReception()
When attach the LAN:
EngineCtrl::linkUp(1000, 1, 0)
EngineCtrl::notifyAuthenticated()
SwFwdEng: switch in learn mode
SwFwdEng: switch is forwarding
EngineCtrl::notifySwitchForwarding()
EngineCtrl::notifyNetworkUp()
Setting Discovery Refresh timer to 90 minutes.
New IP Config
Source IP 160.141.153.250 Mask 255.255.255.000
Router IP 160.141.153.001 DNS 160.141.147.078
