Author Topic: Audio over Bluetooth  (Read 2604 times)
Offline YU7CTopic starter
  • Country: cs
« on: August 01, 2019, 07:42:01 pm »
I need to transfer full audio signal (16bit 20Hz - 20kHz) from Microphone to Windows PC application over Bluetooth, and have selected Microchip BM62 Wireless module.
At the  begining everthing goes flawless: BM62 paired with BT adapter, connected and got BT microphone in Sound.
I got several BT services: Audio Sink, Handsfree Telephony, Headset,...
But audio BW is imited to about 4kHz which told me that only HFP/HSP works, not A2DP.
If I select only A2DP on BM62, then Audio Sink service is only avaliabled but  there is no sound from micropne.
I have connected elecret capsule on the microphone input of BM62.
Perhaps I need line input on BM62 for A2DP audio quality signal?
Does anyone has experinces with BM62?
Thanks,
Vojislav
  • Country: cs
Re: Audio over Bluetooth
« Reply #1 on: August 02, 2019, 04:51:41 am »
A2DP doesn't work with microphone inputs. A2DP is for high quality playback only.
Can I use a line input for audio streaming and A2DP profile?
Thanks,
Vojislav
  • Country: cs
« Reply #2 on: August 02, 2019, 05:51:43 am »
Ok, but anyway I need only one way path, from the device to PC. If it is not possible have to looking for other solution.
Thanks,
Vojislav
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: August 02, 2019, 06:06:16 am »
Not only that. A2DP is also compressed, and receiving a2dp is not possible on Windows.
