Interesting - if I didn't already have a PICKit 2. I have a box full of 16F873/877 (whichever the complementary ones are, where the one has more memory but is otherwise identical). An old circuit I was going to use used the smaller chip, I figured the extra memory wouldn't for the most part break code written for the one with less memory, and so managed to get several dozen as samples. I've since changed my approach and instead of building someone else's interface design using the PIC chips I am designing my own with Atmel micros. I should do something with all those PICs though. Port my code and make some of my board with the PIC, but I'd rather not have a mix of devices, even though it is all for personal use. I suppose if they would be indistinguishable at the sharp end, it wouldn't matter. At any rate, I hate to see a box full of potentially useful chips just go to waste, at some point I'll come up with some project to use them in.
These may be older chips, but there are still plenty of applications that don't need the speed and/or memory of ARm cores and the like. Using faster micros where the project involves mostly waiting for user input just means the thing executes more keyboard scans than a slower one - the old slow ones are more than capable of performing the task.
Neat thing about this - I could just set it up as a shield with a ZIF socket and use the same Arduino with my ATTiny shield, or a PIC shield, depending on what I wanted to program. Effectively one platform for multiple purposes. In fact, if it's possible to change around some of the pins being used - it could be BOTH, depending on the code loaded to the Arduino.
