Thanks for the new project. I've been able to compile the int_test project, but not the PingPong one using the attached makefile. If i use the makefile from int_test with PingPong it will compile succesfully. However, when i run the simulation using the PingPong.bin created from the PingPong folder, it frezees right after initializatation and i don't see any transmitted packets.
This is what i get:
0 TRX R_0 started (-30.00, 30.00)
0 TRX R_1 started (-10.00, 30.00)
0 TRX R_2 started (10.00, 30.00)
0 TRX R_3 started (30.00, 30.00)
0 TRX R_4 started (-30.00, 10.00)
0 TRX R_5 started (-10.00, 10.00)
0 TRX R_6 started (10.00, 10.00)
0 TRX R_7 started (30.00, 10.00)
0 TRX R_8 started (-30.00, -10.00)
0 TRX R_9 started (-10.00, -10.00)
0 TRX R_10 started (10.00, -10.00)
0 TRX R_11 started (30.00, -10.00)
0 TRX R_12 started (-30.00, -30.00)
0 TRX R_13 started (-10.00, -30.00)
0 TRX R_14 started (10.00, -30.00)
0 TRX R_15 started (30.00, -30.00)
200000000 cycles in 44130 ms => 4532064 cycles/sec
Any idea why? Thanks again for all your help. Once i get this example to work, then i can make my own modifications without bothering you.
