* @brief ADC handle Structure definition
#if (USE_HAL_ADC_REGISTER_CALLBACKS == 1)
typedef struct __ADC_HandleTypeDef
#else
typedef struct
#endif
ADC_TypeDef *Instance; /*!< Register base address */
ADC_InitTypeDef Init; /*!< ADC required parameters */
__IO uint32_t NbrOfCurrentConversionRank; /*!< ADC number of current conversion rank */
DMA_HandleTypeDef *DMA_Handle; /*!< Pointer DMA Handler */
HAL_LockTypeDef Lock; /*!< ADC locking object */
__IO uint32_t State; /*!< ADC communication state */
__IO uint32_t ErrorCode; /*!< ADC Error code */
void (* ConvCpltCallback)(struct __ADC_HandleTypeDef *hadc); /*!< ADC conversion complete callback */
void (* ConvHalfCpltCallback)(struct __ADC_HandleTypeDef *hadc); /*!< ADC conversion DMA half-transfer callback */
void (* LevelOutOfWindowCallback)(struct __ADC_HandleTypeDef *hadc); /*!< ADC analog watchdog 1 callback */
void (* ErrorCallback)(struct __ADC_HandleTypeDef *hadc); /*!< ADC error callback */
void (* InjectedConvCpltCallback)(struct __ADC_HandleTypeDef *hadc); /*!< ADC group injected conversion complete callback */
void (* MspInitCallback)(struct __ADC_HandleTypeDef *hadc); /*!< ADC Msp Init callback */
void (* MspDeInitCallback)(struct __ADC_HandleTypeDef *hadc); /*!< ADC Msp DeInit callback */
#endif /* USE_HAL_ADC_REGISTER_CALLBACKS */
}ADC_HandleTypeDef;
#define __HAL_LINKDMA(__HANDLE__, __PPP_DMA_FIELD__, __DMA_HANDLE__) \
do{ \
(__HANDLE__)->__PPP_DMA_FIELD__ = &(__DMA_HANDLE__); \
(__DMA_HANDLE__).Parent = (__HANDLE__); \
} while(0U)
__HAL_LINKDMA(&ADC1_Handle,DMA_Handle,DMA1Channel1_Handle);
It sets up everything for the HAL.
So when the ADC code handles the ADC, it will use ADC1_Handle.DMA_Handle for configuring the DMA.
And when the DMA interrupt happens, it will check the Parent.
It does exactly this:
ADC1_Handle.DMA_Handle = &DMA1Channel1_Handle;
DMA1Channel1_Handle.Parent = &ADC1_Handle;
It doesn't touch the hardware in any way.
I'm pretty sure it's only internal, for the HAL, and you're not supposed to use it.
