Hello folks. Recently I came across a problem using a dspic33fj32mc202 using independent pwm. So what happens is when I set the duty cycle pdc1 half of the ptper(period), then I should get a duty cycle of 50% but the duty cycle I get is 25%. Just like that I get 100% duty cycle when I use value in pdc1 register twice of the value of ptper register. I am using it in free running mode which implies it should operate in edge aligned mode.
Please help if anyone has experience.
Code:
P1TCON=0b0000000000000100;
P1TPER=530;
PWM1CON1bits.PMOD1=1;
PWM1CON1bits.PMOD2=1;
PWM1CON1bits.PEN1H=1;
PWM1CON1bits.PEN1L=1;
PWM1CON1bits.PEN2H=1;
PWM1CON1bits.PEN2L=1;
PWM1CON1bits.PEN3H=0;
PWM1CON1bits.PEN3L=0;
P1DTCON1bits.DTAPS=1;
P1DTCON1bits.DTBPS=1;
P1DTCON1bits.DTA=0;
P1DTCON1bits.DTB=0;
P1FLTACON=0;
//P1DTCON1bits.DTAPS=2;
//P1DTCON1bits.DTA=63;
P1DC1=530;
P1DC2=1060;
P1TCON=0b1000000000000100; //pwm module on
I get 50% duty in pwm1h and pwm1l. which should be 100%.
I get 100% duty in pwm2h and pwm2l pin.
