Author Topic: WTD - Motorola DSP56000 SLAM (100pin ceramic) pinout / DSP56001 Datasheet Supp't  (Read 1019 times)
Offline philpemTopic starter
  • That Sneaky British Bloke
Does anyone happen to have a copy of the pinout for the 100-pin "SLAM" (single-layer aluminium metallised) version of the Motorola DSP56001?
This was apparently published in the DSP56001 Data Sheet Supplement - according to this document: http://downloads.atari-home.de/Scene_Demos/!MAGS/!BONUS/DOCS/FALCON/DSPTXT.TXT
I've just picked up a bunch of these chips at a swapmeet and I'd like to use them for something silly and frivolous!
Phil / M0OFX -- Electronics/Software Engineer
"Why do I have a room full of test gear? Why, it saves on the heating bill!"
Offline tpfaff100
I have a couple of 56000 DSP boards that use that SLAM package.  Given a few weeks I could probably arrange pictures.
What I'm looking for is the C Compiler/cross-compiler to check out.  Also need to see if my NeXTStation/RISC (PA-RISC) has the 56000 assembler... I think it got recompiled for the NIHS release of NeXTStep.
Also I need some of the SLAM packages for that incarnation of the 56000.
Lots easier to route traces with those vs. the QLFP socket or whatever it's called.
Did you get the cute white package or the dark gray colored 56001?
