Okay then. About 12 lines from the bottom there is the message
fatal error: wx/wx.h: No such file or directory
Building in /home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build
~/Downloads/temp/usbdm-eclipse-makefiles-build ~/Downloads/temp/usbdm-eclipse-makefiles-build
make -f Makefile-x64.mk all BITNESS=64
make: wx-config: No such file or directory
make -C UsbdmSystem_DLL all -f Makefile-x64.mk
make[1]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmSystem_DLL'
make[1]: wx-config: No such file or directory
Building usbdm-system 64-bit
make dll -f Target.mk BUILDDIR=usbdm-system CDEFS=''-DCOMPILE_USBDM_SYSTEM_DLL'' BITNESS=64
make[2]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmSystem_DLL'
make[2]: wx-config: No such file or directory
-- Making directory ../PackageFiles/lib/x86_64-linux-gnu
mkdir -p ../PackageFiles/lib/x86_64-linux-gnu
-- Making directory ../PackageFiles/bin/x86_64-linux-gnu
mkdir -p ../PackageFiles/bin/x86_64-linux-gnu
-- Making directory usbdm-system.x86_64-linux-gnu
mkdir -p usbdm-system.x86_64-linux-gnu
-- Building usbdm-system.x86_64-linux-gnu/UsbdmSystem.o from ../Shared/src/UsbdmSystem.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -DCOMPILE_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystem.cpp -o usbdm-system.x86_64-linux-gnu/UsbdmSystem.o
-- Building usbdm-system.x86_64-linux-gnu/ErrorMessages.o from ../Shared/src/ErrorMessages.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -DCOMPILE_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/ErrorMessages.cpp -o usbdm-system.x86_64-linux-gnu/ErrorMessages.o
-- Building usbdm-system.x86_64-linux-gnu/UsbdmSystemLinux.o from ../Shared/src/UsbdmSystemLinux.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -DCOMPILE_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystemLinux.cpp -o usbdm-system.x86_64-linux-gnu/UsbdmSystemLinux.o
-- Linking Target usbdm-system.x86_64-linux-gnu/libusbdm-system.so.4.12
g++ -shared -o usbdm-system.x86_64-linux-gnu/libusbdm-system.so.4.12 -Wl,-soname,libusbdm-system.so.4 -O3 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 usbdm-system.x86_64-linux-gnu/UsbdmSystem.o usbdm-system.x86_64-linux-gnu/ErrorMessages.o usbdm-system.x86_64-linux-gnu/UsbdmSystemLinux.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu
-- Copying usbdm-system.x86_64-linux-gnu/libusbdm-system.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system.so.4.12
cp usbdm-system.x86_64-linux-gnu/libusbdm-system.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system.so.4.12
ln -s -f libusbdm-system.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system.so.4
make[2]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmSystem_DLL'
Building usbdm-system-debug 64-bit
make dll -f Target.mk BUILDDIR=usbdm-system-debug CDEFS=''-DCOMPILE_USBDM_SYSTEM_DLL'' DEBUG='Y' BITNESS=64
-- Making directory usbdm-system-debug.x86_64-linux-gnu
mkdir -p usbdm-system-debug.x86_64-linux-gnu
-- Building usbdm-system-debug.x86_64-linux-gnu/UsbdmSystem.o from ../Shared/src/UsbdmSystem.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -DLOG -DCOMPILE_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystem.cpp -o usbdm-system-debug.x86_64-linux-gnu/UsbdmSystem.o
-- Building usbdm-system-debug.x86_64-linux-gnu/ErrorMessages.o from ../Shared/src/ErrorMessages.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -DLOG -DCOMPILE_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/ErrorMessages.cpp -o usbdm-system-debug.x86_64-linux-gnu/ErrorMessages.o
-- Building usbdm-system-debug.x86_64-linux-gnu/UsbdmSystemLinux.o from ../Shared/src/UsbdmSystemLinux.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -DLOG -DCOMPILE_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystemLinux.cpp -o usbdm-system-debug.x86_64-linux-gnu/UsbdmSystemLinux.o
-- Linking Target usbdm-system-debug.x86_64-linux-gnu/libusbdm-system-debug.so.4.12
g++ -shared -o usbdm-system-debug.x86_64-linux-gnu/libusbdm-system-debug.so.4.12 -Wl,-soname,libusbdm-system-debug.so.4 -O0 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 usbdm-system-debug.x86_64-linux-gnu/UsbdmSystem.o usbdm-system-debug.x86_64-linux-gnu/ErrorMessages.o usbdm-system-debug.x86_64-linux-gnu/UsbdmSystemLinux.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu
-- Copying usbdm-system-debug.x86_64-linux-gnu/libusbdm-system-debug.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system-debug.so.4.12
cp usbdm-system-debug.x86_64-linux-gnu/libusbdm-system-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system-debug.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system-debug.so.4.12
ln -s -f libusbdm-system-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-system-debug.so.4
make[1]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmSystem_DLL'
make -C Usbdm_DLL all -f Makefile-x64.mk
make[1]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/Usbdm_DLL'
Building usbdm 64-bit
make dll -f Target.mk BUILDDIR=usbdm MODULE=usbdm CDEFS='-DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL' BITNESS=64
make[2]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/Usbdm_DLL'
BITNESS = 64
BUILDDIR = usbdm
-- Making directory usbdm.x86_64-linux-gnu
mkdir -p usbdm.x86_64-linux-gnu
-- Building usbdm.x86_64-linux-gnu/armInterface.o from src/armInterface.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/armInterface.cpp -o usbdm.x86_64-linux-gnu/armInterface.o
-- Building usbdm.x86_64-linux-gnu/ICP.o from src/ICP.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/ICP.cpp -o usbdm.x86_64-linux-gnu/ICP.o
-- Building usbdm.x86_64-linux-gnu/JTAGSequence.o from src/JTAGSequence.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/JTAGSequence.cpp -o usbdm.x86_64-linux-gnu/JTAGSequence.o
-- Building usbdm.x86_64-linux-gnu/low_level_usb.o from ../Shared/src/low_level_usb.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/low_level_usb.cpp -o usbdm.x86_64-linux-gnu/low_level_usb.o
../Shared/src/low_level_usb.cpp: In function ‘USBDM_ErrorCode bdm_usb_transaction(unsigned int, unsigned int, unsigned char*, unsigned int, unsigned int*)’:
../Shared/src/low_level_usb.cpp:1356:21: warning: ‘tempRxSize’ may be used uninitialized [-Wmaybe-uninitialized]
1356 | *actualRxSize = tempRxSize;
../Shared/src/low_level_usb.cpp:1334:13: note: ‘tempRxSize’ declared here
1334 | unsigned tempRxSize;
-- Building usbdm.x86_64-linux-gnu/USBDM_API.o from src/USBDM_API.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/USBDM_API.cpp -o usbdm.x86_64-linux-gnu/USBDM_API.o
-- Building usbdm.x86_64-linux-gnu/UsbdmSystem.o from ../Shared/src/UsbdmSystem.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystem.cpp -o usbdm.x86_64-linux-gnu/UsbdmSystem.o
-- Building usbdm.x86_64-linux-gnu/UsbdmSystemLinux.o from ../Shared/src/UsbdmSystemLinux.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystemLinux.cpp -o usbdm.x86_64-linux-gnu/UsbdmSystemLinux.o
-- Building usbdm.x86_64-linux-gnu/ErrorMessages.o from ../Shared/src/ErrorMessages.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/ErrorMessages.cpp -o usbdm.x86_64-linux-gnu/ErrorMessages.o
-- Building usbdm.x86_64-linux-gnu/Names.o from ../Shared/src/Names.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/Names.cpp -o usbdm.x86_64-linux-gnu/Names.o
-- Building usbdm.x86_64-linux-gnu/compat.o from src/compat.c
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/compat.c -o usbdm.x86_64-linux-gnu/compat.o
-- Linking Target usbdm.x86_64-linux-gnu/libusbdm.so.4.12
g++ -shared -o usbdm.x86_64-linux-gnu/libusbdm.so.4.12 -Wl,-soname,libusbdm.so.4 -O3 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 usbdm.x86_64-linux-gnu/armInterface.o usbdm.x86_64-linux-gnu/ICP.o usbdm.x86_64-linux-gnu/JTAGSequence.o usbdm.x86_64-linux-gnu/low_level_usb.o usbdm.x86_64-linux-gnu/USBDM_API.o usbdm.x86_64-linux-gnu/UsbdmSystem.o usbdm.x86_64-linux-gnu/UsbdmSystemLinux.o usbdm.x86_64-linux-gnu/ErrorMessages.o usbdm.x86_64-linux-gnu/Names.o usbdm.x86_64-linux-gnu/compat.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu -lusb-1.0
-- Copying usbdm.x86_64-linux-gnu/libusbdm.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm.so.4.12
cp usbdm.x86_64-linux-gnu/libusbdm.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm.so.4.12
ln -s -f libusbdm.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm.so.4
make[2]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/Usbdm_DLL'
Building usbdm-debug 64-bit
make dll -f Target.mk BUILDDIR=usbdm-debug MODULE=usbdm CDEFS='-DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL' DEBUG='Y' BITNESS=64
BITNESS = 64
BUILDDIR = usbdm-debug
-- Making directory usbdm-debug.x86_64-linux-gnu
mkdir -p usbdm-debug.x86_64-linux-gnu
-- Building usbdm-debug.x86_64-linux-gnu/armInterface.o from src/armInterface.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/armInterface.cpp -o usbdm-debug.x86_64-linux-gnu/armInterface.o
-- Building usbdm-debug.x86_64-linux-gnu/ICP.o from src/ICP.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/ICP.cpp -o usbdm-debug.x86_64-linux-gnu/ICP.o
-- Building usbdm-debug.x86_64-linux-gnu/JTAGSequence.o from src/JTAGSequence.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/JTAGSequence.cpp -o usbdm-debug.x86_64-linux-gnu/JTAGSequence.o
-- Building usbdm-debug.x86_64-linux-gnu/low_level_usb.o from ../Shared/src/low_level_usb.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/low_level_usb.cpp -o usbdm-debug.x86_64-linux-gnu/low_level_usb.o
-- Building usbdm-debug.x86_64-linux-gnu/USBDM_API.o from src/USBDM_API.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/USBDM_API.cpp -o usbdm-debug.x86_64-linux-gnu/USBDM_API.o
-- Building usbdm-debug.x86_64-linux-gnu/UsbdmSystem.o from ../Shared/src/UsbdmSystem.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystem.cpp -o usbdm-debug.x86_64-linux-gnu/UsbdmSystem.o
-- Building usbdm-debug.x86_64-linux-gnu/UsbdmSystemLinux.o from ../Shared/src/UsbdmSystemLinux.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystemLinux.cpp -o usbdm-debug.x86_64-linux-gnu/UsbdmSystemLinux.o
-- Building usbdm-debug.x86_64-linux-gnu/ErrorMessages.o from ../Shared/src/ErrorMessages.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/ErrorMessages.cpp -o usbdm-debug.x86_64-linux-gnu/ErrorMessages.o
-- Building usbdm-debug.x86_64-linux-gnu/Names.o from ../Shared/src/Names.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/Names.cpp -o usbdm-debug.x86_64-linux-gnu/Names.o
-- Building usbdm-debug.x86_64-linux-gnu/compat.o from src/compat.c
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/compat.c -o usbdm-debug.x86_64-linux-gnu/compat.o
-- Linking Target usbdm-debug.x86_64-linux-gnu/libusbdm-debug.so.4.12
g++ -shared -o usbdm-debug.x86_64-linux-gnu/libusbdm-debug.so.4.12 -Wl,-soname,libusbdm-debug.so.4 -O0 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 usbdm-debug.x86_64-linux-gnu/armInterface.o usbdm-debug.x86_64-linux-gnu/ICP.o usbdm-debug.x86_64-linux-gnu/JTAGSequence.o usbdm-debug.x86_64-linux-gnu/low_level_usb.o usbdm-debug.x86_64-linux-gnu/USBDM_API.o usbdm-debug.x86_64-linux-gnu/UsbdmSystem.o usbdm-debug.x86_64-linux-gnu/UsbdmSystemLinux.o usbdm-debug.x86_64-linux-gnu/ErrorMessages.o usbdm-debug.x86_64-linux-gnu/Names.o usbdm-debug.x86_64-linux-gnu/compat.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu -lusb-1.0
-- Copying usbdm-debug.x86_64-linux-gnu/libusbdm-debug.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-debug.so.4.12
cp usbdm-debug.x86_64-linux-gnu/libusbdm-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-debug.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-debug.so.4.12
ln -s -f libusbdm-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-debug.so.4
Building usbdm-static 64-bit
make dll -f Target.mk BUILDDIR=usbdm-static MODULE=usbdm CDEFS='-DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL' LFLAGS='' BITNESS=64
BITNESS = 64
BUILDDIR = usbdm-static
-- Making directory usbdm-static.x86_64-linux-gnu
mkdir -p usbdm-static.x86_64-linux-gnu
-- Building usbdm-static.x86_64-linux-gnu/armInterface.o from src/armInterface.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/armInterface.cpp -o usbdm-static.x86_64-linux-gnu/armInterface.o
-- Building usbdm-static.x86_64-linux-gnu/ICP.o from src/ICP.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/ICP.cpp -o usbdm-static.x86_64-linux-gnu/ICP.o
-- Building usbdm-static.x86_64-linux-gnu/JTAGSequence.o from src/JTAGSequence.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/JTAGSequence.cpp -o usbdm-static.x86_64-linux-gnu/JTAGSequence.o
-- Building usbdm-static.x86_64-linux-gnu/low_level_usb.o from ../Shared/src/low_level_usb.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/low_level_usb.cpp -o usbdm-static.x86_64-linux-gnu/low_level_usb.o
-- Building usbdm-static.x86_64-linux-gnu/USBDM_API.o from src/USBDM_API.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/USBDM_API.cpp -o usbdm-static.x86_64-linux-gnu/USBDM_API.o
-- Building usbdm-static.x86_64-linux-gnu/UsbdmSystem.o from ../Shared/src/UsbdmSystem.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystem.cpp -o usbdm-static.x86_64-linux-gnu/UsbdmSystem.o
-- Building usbdm-static.x86_64-linux-gnu/UsbdmSystemLinux.o from ../Shared/src/UsbdmSystemLinux.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystemLinux.cpp -o usbdm-static.x86_64-linux-gnu/UsbdmSystemLinux.o
-- Building usbdm-static.x86_64-linux-gnu/ErrorMessages.o from ../Shared/src/ErrorMessages.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/ErrorMessages.cpp -o usbdm-static.x86_64-linux-gnu/ErrorMessages.o
-- Building usbdm-static.x86_64-linux-gnu/Names.o from ../Shared/src/Names.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/Names.cpp -o usbdm-static.x86_64-linux-gnu/Names.o
-- Building usbdm-static.x86_64-linux-gnu/compat.o from src/compat.c
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/compat.c -o usbdm-static.x86_64-linux-gnu/compat.o
-- Linking Target usbdm-static.x86_64-linux-gnu/libusbdm-static.so.4.12
g++ -shared -o usbdm-static.x86_64-linux-gnu/libusbdm-static.so.4.12 -Wl,-soname,libusbdm-static.so.4 -O3 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 usbdm-static.x86_64-linux-gnu/armInterface.o usbdm-static.x86_64-linux-gnu/ICP.o usbdm-static.x86_64-linux-gnu/JTAGSequence.o usbdm-static.x86_64-linux-gnu/low_level_usb.o usbdm-static.x86_64-linux-gnu/USBDM_API.o usbdm-static.x86_64-linux-gnu/UsbdmSystem.o usbdm-static.x86_64-linux-gnu/UsbdmSystemLinux.o usbdm-static.x86_64-linux-gnu/ErrorMessages.o usbdm-static.x86_64-linux-gnu/Names.o usbdm-static.x86_64-linux-gnu/compat.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu -lusb-1.0
-- Copying usbdm-static.x86_64-linux-gnu/libusbdm-static.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static.so.4.12
cp usbdm-static.x86_64-linux-gnu/libusbdm-static.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static.so.4.12
ln -s -f libusbdm-static.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static.so.4
Building usbdm-static-debug 64-bit
make dll -f Target.mk BUILDDIR=usbdm-static-debug MODULE=usbdm CDEFS='-DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL' LFLAGS='' DEBUG='Y' BITNESS=64
BITNESS = 64
BUILDDIR = usbdm-static-debug
-- Making directory usbdm-static-debug.x86_64-linux-gnu
mkdir -p usbdm-static-debug.x86_64-linux-gnu
-- Building usbdm-static-debug.x86_64-linux-gnu/armInterface.o from src/armInterface.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/armInterface.cpp -o usbdm-static-debug.x86_64-linux-gnu/armInterface.o
-- Building usbdm-static-debug.x86_64-linux-gnu/ICP.o from src/ICP.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/ICP.cpp -o usbdm-static-debug.x86_64-linux-gnu/ICP.o
-- Building usbdm-static-debug.x86_64-linux-gnu/JTAGSequence.o from src/JTAGSequence.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/JTAGSequence.cpp -o usbdm-static-debug.x86_64-linux-gnu/JTAGSequence.o
-- Building usbdm-static-debug.x86_64-linux-gnu/low_level_usb.o from ../Shared/src/low_level_usb.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/low_level_usb.cpp -o usbdm-static-debug.x86_64-linux-gnu/low_level_usb.o
-- Building usbdm-static-debug.x86_64-linux-gnu/USBDM_API.o from src/USBDM_API.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/USBDM_API.cpp -o usbdm-static-debug.x86_64-linux-gnu/USBDM_API.o
-- Building usbdm-static-debug.x86_64-linux-gnu/UsbdmSystem.o from ../Shared/src/UsbdmSystem.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystem.cpp -o usbdm-static-debug.x86_64-linux-gnu/UsbdmSystem.o
-- Building usbdm-static-debug.x86_64-linux-gnu/UsbdmSystemLinux.o from ../Shared/src/UsbdmSystemLinux.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/UsbdmSystemLinux.cpp -o usbdm-static-debug.x86_64-linux-gnu/UsbdmSystemLinux.o
-- Building usbdm-static-debug.x86_64-linux-gnu/ErrorMessages.o from ../Shared/src/ErrorMessages.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/ErrorMessages.cpp -o usbdm-static-debug.x86_64-linux-gnu/ErrorMessages.o
-- Building usbdm-static-debug.x86_64-linux-gnu/Names.o from ../Shared/src/Names.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c ../Shared/src/Names.cpp -o usbdm-static-debug.x86_64-linux-gnu/Names.o
-- Building usbdm-static-debug.x86_64-linux-gnu/compat.o from src/compat.c
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -DUSBDM_DLL_EXPORTS -DLINK_USBDM_SYSTEM_DLL -Isrc -I../Shared/src -MD -c src/compat.c -o usbdm-static-debug.x86_64-linux-gnu/compat.o
-- Linking Target usbdm-static-debug.x86_64-linux-gnu/libusbdm-static-debug.so.4.12
g++ -shared -o usbdm-static-debug.x86_64-linux-gnu/libusbdm-static-debug.so.4.12 -Wl,-soname,libusbdm-static-debug.so.4 -O0 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 usbdm-static-debug.x86_64-linux-gnu/armInterface.o usbdm-static-debug.x86_64-linux-gnu/ICP.o usbdm-static-debug.x86_64-linux-gnu/JTAGSequence.o usbdm-static-debug.x86_64-linux-gnu/low_level_usb.o usbdm-static-debug.x86_64-linux-gnu/USBDM_API.o usbdm-static-debug.x86_64-linux-gnu/UsbdmSystem.o usbdm-static-debug.x86_64-linux-gnu/UsbdmSystemLinux.o usbdm-static-debug.x86_64-linux-gnu/ErrorMessages.o usbdm-static-debug.x86_64-linux-gnu/Names.o usbdm-static-debug.x86_64-linux-gnu/compat.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu -lusb-1.0
-- Copying usbdm-static-debug.x86_64-linux-gnu/libusbdm-static-debug.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static-debug.so.4.12
cp usbdm-static-debug.x86_64-linux-gnu/libusbdm-static-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static-debug.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static-debug.so.4.12
ln -s -f libusbdm-static-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-static-debug.so.4
make[1]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/Usbdm_DLL'
make -C UsbdmJni_DLL all -f Makefile-x64.mk
make[1]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmJni_DLL'
Building usbdm-jni 64-bit
make dll -f Target.mk BUILDDIR=usbdm-jni CDEFS='' BITNESS=64
make[2]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmJni_DLL'
-- Making directory usbdm-jni.x86_64-linux-gnu
mkdir -p usbdm-jni.x86_64-linux-gnu
-- Building usbdm-jni.x86_64-linux-gnu/UsbdmJniWrapper.o from src/UsbdmJniWrapper.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -Isrc -I/usr/lib/jvm/default-java/include -I/usr/lib/jvm/default-java/include/linux -I../Shared/src -MD -c src/UsbdmJniWrapper.cpp -o usbdm-jni.x86_64-linux-gnu/UsbdmJniWrapper.o
-- Building usbdm-jni.x86_64-linux-gnu/LinuxPaths.o from src/LinuxPaths.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -Isrc -I/usr/lib/jvm/default-java/include -I/usr/lib/jvm/default-java/include/linux -I../Shared/src -MD -c src/LinuxPaths.cpp -o usbdm-jni.x86_64-linux-gnu/LinuxPaths.o
-- Linking Target usbdm-jni.x86_64-linux-gnu/libusbdm-jni.so.4.12
g++ -shared -o usbdm-jni.x86_64-linux-gnu/libusbdm-jni.so.4.12 -Wl,-soname,libusbdm-jni.so.4 -O3 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 -Wl,-soname,libusbdm-jni.so.4 usbdm-jni.x86_64-linux-gnu/UsbdmJniWrapper.o usbdm-jni.x86_64-linux-gnu/LinuxPaths.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu -lusbdm
-- Copying usbdm-jni.x86_64-linux-gnu/libusbdm-jni.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni.so.4.12
cp usbdm-jni.x86_64-linux-gnu/libusbdm-jni.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni.so.4.12
ln -s -f libusbdm-jni.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni.so.4
make[2]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmJni_DLL'
Building usbdm-jni-debug 64-bit
make dll -f Target.mk BUILDDIR=usbdm-jni-debug CDEFS='' DEBUG='Y' BITNESS=64
-- Making directory usbdm-jni-debug.x86_64-linux-gnu
mkdir -p usbdm-jni-debug.x86_64-linux-gnu
-- Building usbdm-jni-debug.x86_64-linux-gnu/UsbdmJniWrapper.o from src/UsbdmJniWrapper.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -Isrc -I/usr/lib/jvm/default-java/include -I/usr/lib/jvm/default-java/include/linux -I../Shared/src -MD -c src/UsbdmJniWrapper.cpp -o usbdm-jni-debug.x86_64-linux-gnu/UsbdmJniWrapper.o
-- Building usbdm-jni-debug.x86_64-linux-gnu/LinuxPaths.o from src/LinuxPaths.cpp
g++ -fPIC -O0 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -fno-exceptions -DLOG -Isrc -I/usr/lib/jvm/default-java/include -I/usr/lib/jvm/default-java/include/linux -I../Shared/src -MD -c src/LinuxPaths.cpp -o usbdm-jni-debug.x86_64-linux-gnu/LinuxPaths.o
-- Linking Target usbdm-jni-debug.x86_64-linux-gnu/libusbdm-jni-debug.so.4.12
g++ -shared -o usbdm-jni-debug.x86_64-linux-gnu/libusbdm-jni-debug.so.4.12 -Wl,-soname,libusbdm-jni-debug.so.4 -O0 -g3 -Wl,-rpath,"/usr/lib/x86_64-linux-gnu/usbdm" -Wl,-rpath-link,../Shared/x86_64-linux-gnu -Wl,-rpath-link,../PackageFiles/lib/x86_64-linux-gnu -m64 -Wl,-soname,libusbdm-jni-debug.so.4 usbdm-jni-debug.x86_64-linux-gnu/UsbdmJniWrapper.o usbdm-jni-debug.x86_64-linux-gnu/LinuxPaths.o -L../PackageFiles/lib/x86_64-linux-gnu -L../Shared/x86_64-linux-gnu -lusbdm-debug
-- Copying usbdm-jni-debug.x86_64-linux-gnu/libusbdm-jni-debug.so.4.12 to ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni-debug.so.4.12
cp usbdm-jni-debug.x86_64-linux-gnu/libusbdm-jni-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni-debug.so.4.12
strip --strip-unneeded ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni-debug.so.4.12
ln -s -f libusbdm-jni-debug.so.4.12 ../PackageFiles/lib/x86_64-linux-gnu/libusbdm-jni-debug.so.4
make[1]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmJni_DLL'
make -C UsbdmWx_DLL all -f Makefile-x64.mk
make[1]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmWx_DLL'
Building usbdm-wx-plugin 64-bit
make dll -f Target.mk BUILDDIR=usbdm-wx-plugin CDEFS='-DMINIMAL_APP=wxPluginApp -DCOMPILE_WX_PLUGIN_DLL' BITNESS=64
make[2]: Entering directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmWx_DLL'
-- Making directory usbdm-wx-plugin.x86_64-linux-gnu
mkdir -p usbdm-wx-plugin.x86_64-linux-gnu
-- Building usbdm-wx-plugin.x86_64-linux-gnu/WxPluginImp.o from src/WxPluginImp.cpp
g++ -fPIC -O3 -g3 -m64 -std=gnu++17 -Wall -shared -fvisibility=hidden -fvisibility-inlines-hidden -DMINIMAL_APP=wxPluginApp -DCOMPILE_WX_PLUGIN_DLL -DuseWxWidgets -Isrc -I../Shared/src -MD -c src/WxPluginImp.cpp -o usbdm-wx-plugin.x86_64-linux-gnu/WxPluginImp.o
src/WxPluginImp.cpp:16:10: fatal error: wx/wx.h: No such file or directory
16 | #include <wx/wx.h>
compilation terminated.
make[2]: *** [Target.mk:93: usbdm-wx-plugin.x86_64-linux-gnu/WxPluginImp.o] Error 1
make[2]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmWx_DLL'
make[1]: *** [Makefile-x64.mk:11: usbdm-wx-plugin] Error 2
make[1]: Leaving directory '/home/my-name/Downloads/temp/usbdm-eclipse-makefiles-build/UsbdmWx_DLL'
make: *** [Makefile-x64.mk:59: build-UsbdmWx_DLL] Error 2
64-bit Make failed
Press any key to continue...
my-name@lappy:~/Downloads/temp/usbdm-eclipse-makefiles-build$
