Author Topic: Bypass caps  (Read 12405 times)
Offline uncle_bob
Re: Bypass caps
« Reply #25 on: April 30, 2016, 09:56:42 pm »
Hi
One of the things that the Murata manual shows are plots of the field around the power traces. Dave has a set of probes (and an amp) that pop up in various videos. They are very useful (and a bit pricy) for figuring this sort of thing out.
Bob
Offline jnz
Re: Bypass caps
« Reply #26 on: May 03, 2016, 02:55:06 pm »
Here's pretty much all you could ever want to know about bypass caps, from Murata: http://www.murata.com/~/media/webrenewal/support/library/catalog/products/emc/emifil/c39e.ashx
That's a really great link! Worth the read.
Offline dannyf
Re: Bypass caps
« Reply #27 on: May 03, 2016, 03:55:04 pm »
how do you make these decisions?
All you need to make sure is that the bypass cap is sufficiently fast - they are there for the transients. I have a ton of .1uf but sometimes I have used small eletrolytics as well.
