Author Topic: [AVR Mega 0 series] interrupt vectors  (Read 1300 times)
Offline SimonTopic starter
  • Global Moderator
    • Simon's Electronics
« on: February 07, 2021, 10:38:24 am »
Where do I find the list of AVR-libc / GCC interrupt vectors for the new Mega 0 series? I wish which ever asshole at Microchip or Atmel that decided to recycle the Mega name could be fired! it was the most stupid thing they ever did, you can't find any information about them as any search will bring up decades of information about completely different chips that had that name first. That Mr. D. Head must still be working there........
Offline mikerj
Re: [AVR Mega 0 series] interrupt vectors
« Reply #1 on: February 07, 2021, 10:52:31 am »
Literally a few seconds on Google found the Family datasheet listing the interrupt vectors on page 50.
Why are the majority of your posts whinging about everything being someone else's fault?  It's getting quite boring.
  • Global Moderator
« Reply #2 on: February 07, 2021, 10:59:28 am »
it was a stupid idea to re use the name, it causes utter confusion, they are two different types of chip entirely and were in fact the xmega. The list on the datasheet is all well and good, but what are the magic words for the interrupt handler?
For the legacy mega's (see I actually have to change the name now of something that had an accepted name to make it clear which one of the two things with the same name I am talking about) I would go here: https://www.nongnu.org/avr-libc/user-manual/group__avr__interrupts.html , which yea, 5s on google can be found and used.
No such thing exists for the 0 - series.
  • Global Moderator
« Reply #3 on: February 07, 2021, 11:07:34 am »
iom3208.h that is called up in AS has a list that I assume is it.
/* ========== Interrupt Vector Definitions ========== */
/* Vector 0 is the reset vector */
/* CRCSCAN interrupt vectors */
#define CRCSCAN_NMI_vect_num  1
#define CRCSCAN_NMI_vect      _VECTOR(1)  /*  */
/* BOD interrupt vectors */
#define BOD_VLM_vect_num  2
#define BOD_VLM_vect      _VECTOR(2)  /*  */
/* RTC interrupt vectors */
#define RTC_CNT_vect_num  3
#define RTC_CNT_vect      _VECTOR(3)  /*  */
#define RTC_PIT_vect_num  4
#define RTC_PIT_vect      _VECTOR(4)  /*  */
/* CCL interrupt vectors */
#define CCL_CCL_vect_num  5
#define CCL_CCL_vect      _VECTOR(5)  /*  */
/* PORTA interrupt vectors */
#define PORTA_PORT_vect_num  6
#define PORTA_PORT_vect      _VECTOR(6)  /*  */
/* TCA0 interrupt vectors */
#define TCA0_LUNF_vect_num  7
#define TCA0_LUNF_vect      _VECTOR(7)  /*  */
#define TCA0_OVF_vect_num  7
#define TCA0_OVF_vect      _VECTOR(7)  /*  */
#define TCA0_HUNF_vect_num  8
#define TCA0_HUNF_vect      _VECTOR(8)  /*  */
#define TCA0_LCMP0_vect_num  9
#define TCA0_LCMP0_vect      _VECTOR(9)  /*  */
#define TCA0_CMP0_vect_num  9
#define TCA0_CMP0_vect      _VECTOR(9)  /*  */
#define TCA0_CMP1_vect_num  10
#define TCA0_CMP1_vect      _VECTOR(10)  /*  */
#define TCA0_LCMP1_vect_num  10
#define TCA0_LCMP1_vect      _VECTOR(10)  /*  */
#define TCA0_CMP2_vect_num  11
#define TCA0_CMP2_vect      _VECTOR(11)  /*  */
#define TCA0_LCMP2_vect_num  11
#define TCA0_LCMP2_vect      _VECTOR(11)  /*  */
/* TCB0 interrupt vectors */
#define TCB0_INT_vect_num  12
#define TCB0_INT_vect      _VECTOR(12)  /*  */
/* TCB1 interrupt vectors */
#define TCB1_INT_vect_num  13
#define TCB1_INT_vect      _VECTOR(13)  /*  */
/* TWI0 interrupt vectors */
#define TWI0_TWIS_vect_num  14
#define TWI0_TWIS_vect      _VECTOR(14)  /*  */
#define TWI0_TWIM_vect_num  15
#define TWI0_TWIM_vect      _VECTOR(15)  /*  */
/* SPI0 interrupt vectors */
#define SPI0_INT_vect_num  16
#define SPI0_INT_vect      _VECTOR(16)  /*  */
/* USART0 interrupt vectors */
#define USART0_RXC_vect_num  17
#define USART0_RXC_vect      _VECTOR(17)  /*  */
#define USART0_DRE_vect_num  18
#define USART0_DRE_vect      _VECTOR(18)  /*  */
#define USART0_TXC_vect_num  19
#define USART0_TXC_vect      _VECTOR(19)  /*  */
/* PORTD interrupt vectors */
#define PORTD_PORT_vect_num  20
#define PORTD_PORT_vect      _VECTOR(20)  /*  */
/* AC0 interrupt vectors */
#define AC0_AC_vect_num  21
#define AC0_AC_vect      _VECTOR(21)  /*  */
/* ADC0 interrupt vectors */
#define ADC0_RESRDY_vect_num  22
#define ADC0_RESRDY_vect      _VECTOR(22)  /*  */
#define ADC0_WCOMP_vect_num  23
#define ADC0_WCOMP_vect      _VECTOR(23)  /*  */
/* PORTC interrupt vectors */
#define PORTC_PORT_vect_num  24
#define PORTC_PORT_vect      _VECTOR(24)  /*  */
/* TCB2 interrupt vectors */
#define TCB2_INT_vect_num  25
#define TCB2_INT_vect      _VECTOR(25)  /*  */
/* USART1 interrupt vectors */
#define USART1_RXC_vect_num  26
#define USART1_RXC_vect      _VECTOR(26)  /*  */
#define USART1_DRE_vect_num  27
#define USART1_DRE_vect      _VECTOR(27)  /*  */
#define USART1_TXC_vect_num  28
#define USART1_TXC_vect      _VECTOR(28)  /*  */
/* PORTF interrupt vectors */
#define PORTF_PORT_vect_num  29
#define PORTF_PORT_vect      _VECTOR(29)  /*  */
/* NVMCTRL interrupt vectors */
#define NVMCTRL_EE_vect_num  30
#define NVMCTRL_EE_vect      _VECTOR(30)  /*  */
/* USART2 interrupt vectors */
#define USART2_RXC_vect_num  31
#define USART2_RXC_vect      _VECTOR(31)  /*  */
#define USART2_DRE_vect_num  32
#define USART2_DRE_vect      _VECTOR(32)  /*  */
#define USART2_TXC_vect_num  33
#define USART2_TXC_vect      _VECTOR(33)  /*  */
/* PORTB interrupt vectors */
#define PORTB_PORT_vect_num  34
#define PORTB_PORT_vect      _VECTOR(34)  /*  */
/* PORTE interrupt vectors */
#define PORTE_PORT_vect_num  35
#define PORTE_PORT_vect      _VECTOR(35)  /*  */
#define _VECTOR_SIZE 4 /* Size of individual vector. */
#define _VECTORS_SIZE (36 * _VECTOR_SIZE)
  • Global Moderator
« Reply #4 on: February 07, 2021, 11:13:27 am »
In case you missed the reference:
