Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
St link utility with Nucleo F401RE
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: St link utility with Nucleo F401RE (Read 1241 times)
lorenrus
Regular Contributor
Country:
on:
January 24, 2019, 05:38:06 pm »
Hi
i have to modify the value of some registers to unable the ETM.
i'm using st link utility. I can search the address of my register but when i modify it's value i have an error, view the image.
Thank you very much
Logged
nsrmagazin
Regular Contributor
Country:
Re: St link utility with Nucleo F401RE
Reply #1 on:
January 24, 2019, 06:33:23 pm »
It seems like you do not have access to the memory. It might be damaged, the cable to be damaged or the programming device.
Logged
Hi all!
If you like the post, please press "thanks".
lorenrus
lorenrus
Regular Contributor
Country:
Reply #2 on:
January 24, 2019, 07:12:39 pm »
Hi and thanks for reply.
hi tried to use another cable but the result is the same.
What do you advise me to do ?
Thank you very much
Lorenzo
Logged
nsrmagazin
Regular Contributor
Country:
Reply #3 on:
January 25, 2019, 08:54:31 am »
Can you try to use another memory, another programmer or test the setup on another computer(virtual machine will also do) or check if the settings for this device are ok. Maybe its not getting VCC or ground on some pin that should be connected.
Logged
Hi all!
lorenrus
Regular Contributor
Country:
Reply #4 on:
January 25, 2019, 09:31:37 am »
Hi
i'm using only tha cable USB - USBMINI.
When i linked my board i opened St Link i pushed the voice Target and after the voice Connect and the result is shown in the image.
In the image tool st link told me that is connnected with my board but if you see the Underlined part .. NORMAL CONNECTION. Is correct this type of connection if i want to modify the value of registers ?
Thank you very much
Lorenzo
Logged
lorenrus
Regular Contributor
Country:
Reply #5 on:
January 25, 2019, 03:12:17 pm »
I have to activate the card ETM and I found that I can edit the register ETMCR.
Thank you
Lorenzo
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
