A basic shell is not that hard to write yourself. The first task is to accumulate a line of text from a keyboard, UART, USB connection or whatever. Depending on how much line editing you need, it can be half-a-page of code (mine does backspace/delete and ^U to nuke the whole line). The trick to making it truly portable is is factoring the code so it'll work with blocking calls like getc() and also with interrupt routines that give you a character at a time.
Then you'll need some kind of service entry point to see if a complete line of text has been collected, parse it, and look up the command to execute in some sort of list. Figuring out how to collect/represent the list of all commands known by the shell is the interesting part, IMO. Most implementations I've seen have commands appear in a monolithic table, which means that part of your code needs to know about *all* the commands supported by the system. That's a pain because when you want to add some new whizzy command for your latest project, you have to patch that in somehow to the list of boilerplate commands you want to be available in every shell. It's not conceptually difficult, it's just messy from a code management point of view.
My approach was to skip the monolithic table and build up a linked list of available shell commands at runtime (via C++ constructors). I don't really care if looking up a shell command by name is O(N). The advantage is that simply constructing an instance of the shell command class adds it into the list, so the generic shell source code doesn't need to know about what commands are available. In fact, there's no list of commands in the source code at all--it's built at runtime.
For instance, whenever you implement a new device driver, you can also add a shell command to talk to it. The shell command is closely associated with the device it's talking to and usually lives in the same source file as the driver. Add that driver to a new project, and you automatically get the shell command with it. Very cool.
The first thing I do in a new project is blink an LED. The next thing is to bring up a command-line shell. It's a great way to get stuff running quickly.
